shanec86 Posted October 8, 2011 Share Posted October 8, 2011 (edited) All parts are located in Langwarrin, Vic Pickup only on the larger items Anything that is marked as free is pickup, if you want me to send it to you its going to cost postage. Reply here or PM me for Mobile number. Thanks, Shane -----R31 Parts----- Sedan RB30 Auto tailshaft - $20 Front Swaybar standard - $10 2x Rear lower control arms - $20 Auto RB30 R31 radiator from TI, was on my drift car, has 'holes' for thermo fans.. not ACTUAL holes that leak. - $20 R31 Sedan Standard Springs x4 - $20 R31 Sedan rear glass x4 - $10 R31 Manual Rb30 starter motor - $20 4 Gauge cluster, shows 260k i think - $10 Grey drivers seat - $10 4x Arm rests, grey/grey trim - $10 R31 RB30 Airbox with awesome Nissan cover. K&N Filter and AFM - $50 TI rear spoiler in stormy glow silver - $10 R31 Sedan series 3 tank. Was Wire brushed and painted in underbody paint, clean as a whistle inside, has good sender unit with a Brand new genuine fuel pump (has only done 100km). Wires on the sender are damaged cause im an idiot, can repair for you if unable to do yourself. - $150 2x R31 Panhard rods - $10 each 4x Blue R31 TI Door trims + 4x Auto Window regs - $100 *can get picture on request* Ganador Aero mirrors (electric) - $150 MORE BELOW Edited October 8, 2011 by shanec86 Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/ Share on other sites More sharing options...
shanec86 Posted October 8, 2011 Author Share Posted October 8, 2011 (edited) -----R33 Parts----- R33 GTST manual Rear cradle + arms + LSD diff + brackets - $200 Custom Roof lining with flames and 'S' Logo - $30 use black vinyl paint on it if you have to! GTST front pipe - $10 White (with a pearl i think) drivers door - $40 2x white side skirts which have some small bits of damage - $FREE White Passenger guard with badge, has some repaired damage (still needs some work) - $20 Burgundy drivers door - $40 Burdungy Guards S1 - $40 each R33 Passenger A Pillar trim, Door sill trim, weather strip - $5 each Original Electric antenna incl switch - $15 Clutch Master Cyl - $15 Boot lock with nissan flap - $5 Boot catch - $Free White boot hinges + struts - $5ea Standard Horns x2 - $5 Int. Wiper control - $Free Speed chime - $Free Purge Canister - $Free Engine Mount unsure which side - $Free Petrol Cap - $Free Air con pipe - $Free Wiper arm - $Free Accel. Cable - $Free White Petrol door $5 Passenger Window Reg assy - $20 Rear wiper motor $5 Seal in picture - $Free Assorted Intercooler piping Turbo Inlet pipe Manual Clutch Pedal + Brake Pedal - $40 Heater Hoses - $5 Fuel Sender - $10 Drivers door switches (cannot confirm if they work i dont have an R33 anymore - $10 in this case Climate Control - $30 Turbo Timer fits into ash tray hole - $15 Black handbrake boot - $5 Din gauge holder (made out of wood/vinyl) - $5 Climate control air temp sensor - $Free Neutral check switch for alarm - $Free Various plastics (rear wiper, mirror trim, seat mounts, blank plate, key surround) - $Free clips, alarm siren, aerial adaptor, Razo gear knob (top worn) - $Free Steering wheel clock spring, not sure if its any good - $Free MORE BELOW Edited October 8, 2011 by shanec86 Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6050826 Share on other sites More sharing options...
shanec86 Posted October 8, 2011 Author Share Posted October 8, 2011 (edited) ------more r33------ Interior Light - $5 Map Light x2 - $5 ea Fuse cover, tiny part broken you can see in pic - $Free Full Stalk Setup - $25 Headlight Stalk only - $10 Manual Gear boot - $10 Another - $5 Left side speaker grill with child restraint bolt - $free Front Speakers - $Free Cluster surround - $Free R33 GTSt 2x Front Struts - $50 R33 GTSt 2x Front Struts - $50 R33 GTSt Caster Arms - $40 R33 GTSt Caster arm brackets and sway bar - $25 R33 GTSt burgundy mud flaps - $5 ea MORE BELOW Edited October 8, 2011 by shanec86 Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6050829 Share on other sites More sharing options...
shanec86 Posted October 8, 2011 Author Share Posted October 8, 2011 (edited) -----R34 Parts----- R34 RB25DE NEO STANDARD coilpacks (1 flakey, were replaced with the splitfires) - $150 or $30 each R34 GT Climate Control, GPS, TV, Radio Cassette $150 - was flakey at best. Driving along the screen would start working and display messages (have pictures of that somewhere) Perfect for the Climate control at least, or parts if you want to diagnose your system R34 Passenger Door Window Electric motor - $10 R34 GT Stainless Steel Catback Exhaust. Kakimoto 2 1/2" to Canon Muffler Pretty loud, sounds cool though - $200 will get a picture of the whole thing if anyones interested R34 GT Standard height Springs (1 rear spring i dont think is any good though cause its been cut by an idiot) - $40 R34 GT standard rear struts 1 is a little better than the other (and im pretty sure the ARE R34 please correct me if im wrong) - $30 R34 GT standard front strut (other one was rubbish, and again im pretty sure it is R34 so correct me if wrong) - $10 -----Non Specific Parts------ Genuine Nissan / Alpine double din 3 cd stacker headunit + radio/cassette - $30 Pivot 'auto' turbo timer - $15 Brand new Oil Catch Can Missing one of the red fitting, hose and a hose clamp. - $15 Red air horns, just hook up ground and 12v wire with terminals - $10 Racing Fuel cell, has foam insert with 2 fittings and filler cap, 200x300x700mm - Price engineering. Heavy gauge alloy suit drop tank if needed. - $50 2 1/2" Polished muffler with 2x 3" straight tips. Has a smallish dent in the side, got it like that new and they wouldnt replace it so i bought another from somewhere else. - $40 (payed $150 odd delivered a couple of years ago) Clear Front indicators - $15 Y32 Cima Gear - $Offers 4x AVON Full slick 250/620R17. Best suited to a 9-10" rim. I Have done one outing on these at winton. No longer need them, tread is still in excellent condition as you can see from the wear indicator. These are a well known brand and a pretty wide slick - $200 They are stored off the ground undercover too. Audiline 2ch Amp - $10 Power acoustic 1ch Amp - $10 Momo Steering wheel (can measure diameter if you need, and not sure if i have the horn centres as pictured anymore) - $15 http://i58.photobucket.com/albums/g272/shanec86/forsale/Image137.jpg ----------------------------------- Also if people are interested i have these for sale: (can provide pics, more info, prices) 5lt (308) ex torana race engine + oz 4spd manual (can include tailshaft to suit Z if you are so inclined) http://i58.photobucket.com/albums/g272/shanec86/forsale/19f79a62.jpg http://i58.photobucket.com/albums/g272/shanec86/forsale/11a7aab4.jpg EOI on RB25DET (S1 R33) + RB30 Bottom End LG KG 800 hardly used in box Nokia N95, needs power button repaired Adaptec Raid card - 2 port PCIe Asus R2H UMPC tablet Intel server, Dual CPU Dual Core Xeon HT, 2x 74 gb raptors, 4 barracuda drives 120gb, dvd burner, genuine 03 server, raid card. New ford racing backpack / satchel Sun Micro Sunfire V100 Server Edited October 8, 2011 by shanec86 Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6050830 Share on other sites More sharing options...
Count Grantleyish Posted October 8, 2011 Share Posted October 8, 2011 Hi Shane, Bit odd I know but wouldn't you happen to have number plate brackets that is metal piece that bolts up to reinforcment bar (I think it's found on S1/1.5 R33 as well GTR's) laying around by any chance? PM me if you do. Cheers Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6050849 Share on other sites More sharing options...
shanec86 Posted October 8, 2011 Author Share Posted October 8, 2011 PM Sent Also i just realised that i dont know which coilpack was the faulty one? So at this point i wont sell them individually haha Ill have to open the box right up i may have marked one Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6051258 Share on other sites More sharing options...
shanec86 Posted October 9, 2011 Author Share Posted October 9, 2011 twin tip muffler is sold. Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6051579 Share on other sites More sharing options...
photonmoo Posted October 9, 2011 Share Posted October 9, 2011 (edited) I'm interested (will take) in the polished muffler. Ah F**k only saw now that the muffler is sold And if possible, could do you have some more pics of the catback exhaust please? Edited October 9, 2011 by photonmoo Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6052191 Share on other sites More sharing options...
shanec86 Posted October 9, 2011 Author Share Posted October 9, 2011 no worries, ill get some pictures of it Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6052548 Share on other sites More sharing options...
shanec86 Posted October 10, 2011 Author Share Posted October 10, 2011 Pictures of the 34 Catback: also after getting it off the car ive noticed the muffler has a rattle in it, i think some of the baffle might have come loose. Didnt notice any problem on the car It has a silencer too Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6054044 Share on other sites More sharing options...
shanec86 Posted October 10, 2011 Author Share Posted October 10, 2011 R31 Standard fuel tank sold Airhorns pending payment Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6054095 Share on other sites More sharing options...
photonmoo Posted October 10, 2011 Share Posted October 10, 2011 Is the clear front indicators for a r34? Hmm, I'll have to get back to you on the exhaust too Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6054231 Share on other sites More sharing options...
shanec86 Posted October 10, 2011 Author Share Posted October 10, 2011 not 100% sure what the indicators are off pretty sure they are off a 4x4 of some sort. Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6054289 Share on other sites More sharing options...
rgr34 Posted October 11, 2011 Share Posted October 11, 2011 dont think the clear indicators are going to fit a r34 front bar.... Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6055068 Share on other sites More sharing options...
EMB RB25 Posted October 11, 2011 Share Posted October 11, 2011 mate have you got the center console trim for a er34 Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6055194 Share on other sites More sharing options...
shanec86 Posted October 11, 2011 Author Share Posted October 11, 2011 No im not wrecking an r34. Its just things that have been changed on the R34, so only whats listed. Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6055413 Share on other sites More sharing options...
Deli Rep Posted October 11, 2011 Share Posted October 11, 2011 I'm 90% sure those rear shocks aren't 34 man... 34 are the fork style bottom rather than the eyelet style. Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6055466 Share on other sites More sharing options...
shanec86 Posted October 11, 2011 Author Share Posted October 11, 2011 R34 GT has eyelet same as R33 GTST R34 GTT has fork Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6055618 Share on other sites More sharing options...
shanec86 Posted October 11, 2011 Author Share Posted October 11, 2011 Fuel Cell sold pending payment Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6055843 Share on other sites More sharing options...
davoud Posted October 12, 2011 Share Posted October 12, 2011 Hey mate,Is the window switch for r33 S1 or S2? If s1 i want it thanks. Link to comment https://www.sau.com.au/forums/topic/379444-vic-heaps-of-parts-r31-r33-r34/#findComment-6058344 Share on other sites More sharing options...
