Hello all :)
I wont go into too much detail, as its a boring story, but unfortunately I have a crack in my R34 GTT NEO head that cant be repaired. My issue is this, I simply cannot get hold of a replacement anywhere in the UK. So this has got me thinking about the standard RB25DET head, will it fit and work? I know that the neo has VVT and therefore revs higher than the standard head and that the cas wiring is different. But other than that will it work?
Thanks in advance
https://www.sau.com.au/forums/topic/379447-r34-cylinder-head-cracked/
Um......not a great idea. The Neo combustion chambers are a different size and the pistons are different as a result. Put an older 25 head on it and the compression should go through the floor.
this. bad idea
I have had the block bored to 87mm and now have Tomei forged pistons and Eagle rods, the pistons have been machined to account for the valve pockets and the compression is good. I am just curious to hear if anyone has done such a thing with the head, as I am a bit stuck. I suppose I could get the head tig welded and run it for a while until a neo head comes available.
As I say, I am a bit stuffed at the moment as I need to come up with a workable solution to my problem of not being able to get a NEO head and as the garage is charging me per day (as whilst my car is in they are loosing money due to my car taking up space)
I guess I could put a R33 GTST head on, swap the internals (other than the lifters) and change the wiring on the cas. But I am just lost and have no idea what to do :(
As above, just tow the car home and buy a neo head or full engine from one of Australia's many wreckers or even off SAU. Plenty of friendly helpful folk on here (who also sometimes happen to have lots of spares haha).
If you can't get any help, i've seen many a people on here offer someone a bit of money to do some shopping/running around and packing/posting. A head shouldn't be hard to ship to the UK.
That's a bit BS about charging you per day because your car is taking up space... must be a really small workshop or something. My car is also at a workshop at the moment, with two engines sitting on their floor and a gearbox plus misc bits. I'm waiting for parts to be made/delivered and they're not charging me any holding fee etc. Not that i did it on purpose though, they pulled the dead motor out then said you need blah blah blah before we feel comfortable putting new motor in.
GL
Where is the crack? Got a picture of it?
I've only ever seen one rb head crack and he was running methanol and 60 pound boost
this
very rare for an RB head to actually crack under normal conditions. are you absolutly sure it is not repairable?
Shipping a head to the UK isn't unfeasible, it won't be that cheap, but it won't be ridiculously expensive either.
If you organise the freight I'm sure a seller wouldn't have an issue shipping it, the issue is finding a neo head, they get snapped up in seconds even here and in Japan where they are readily available.
I would suggest contacting Jesse Streeter and getting one direct from japan, probably your best bet, get the car towed home until you can find one. Also take pictures of the head for us. How did you crack it, run the engine without coolant or something?
Edited by Rolls
I will get some photos as soon as I can, the car will be coming back home this week and with any luck you may look at it and say thats its ok to be tig welded. Unfortunately I dont know how it cracked, plenty of coolant in there. Fingers crossed all will be well.
Who told you it can't be fixed? First off take it to a cylinder head shop for a look. If it is a fine crack you can get the head x-rayed. There are specialist welders who can repair most anything these days.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
