Hi every1, Ive recently bought a 34 gtt as my daily until i find my gtr.
I have noticed that under any load, 5th gear is starting to get resistance while trying to put it in.
It is okay when driving around town, but when on freeway its obvious. Doesnt happen when shifting down, only up in to 5th.
Had a similar issue with my 350z and had to get the box rebuilt and a new synchro put in to fix it (cost me $1500).
But my 350z would crunch hard, this doesnt. There is a slight noise but still slots in pretty easily.
Im assuming the synchro for 5th is on the way out, any1 have any suggestions where is the best place to take it and a idea on cost? I live in Rouse Hill in Sydney.
Still deciding whether to fix it or just try and live with it until it completely breaks.
Thanx in advance.
Rouse Hill? Call Unigroup Engineering, talk to Yavuz, tell him you need redline shockproof put though your gearbox for you and book it in. Mention that the club sent you and the price will be good.
Problem solved
Hello Sean, thanx for the reply. I believe the previous owner already changed the gearbox oil (not sure what was put in though) and problem still remains.
Dont know if its of relevance but car is putting out 250rwkw and has a Exedy heavy duty clutch with plenty of meat on it.
Edited by iwanta34gtr
Problem solved
Thanx for the tip. I will call them on Monday morning.
I was researching the fault and found reference to redline shockproof in this thread - http://www.skylinesa...chros-5th-gear/
I also see the seller of the car made a post in there back in 2008 so looks like this faults been present on the car for a few years.
Are we sure that shockproof will make a difference? All other gears are fine. Its just 5th.
Thank u again i really appreciate ur help.
I haven't stripped a 25 box for a while but I think you can get rev and 5th off without pressing everything out of the centre plate.
From memory the genuine Nissan parts are not cheap it will probably cost between $400-$600 just in syncros, bearings, seals and oil etc. Just to do a quick repair.
Don't take this as gospel but it might be work asking the question if it can be done, good luck.
Its the common fix for crunchy boxes, well not a fix, more of a band aid. It costs a lot less than buying all the parts and fixing the box internals so most owners will put the oil in (nickname is smurf blood due to the colour) and live happily with it
Fantastic Steve, thanx again for the info.
I asked the seller and have gone through some service receipts. The box currently has Royal Purple synchromax in it.
Is this good quality? Or is it still worth changing to the shockproof stuff?
Royal Purple is good stuff.. its quite pricey too, if you can live with it till your next gearbox oil change do it then otherwise you can spend the $100 and try the smurfs blood to see if it makes it any better..
Thank u, I called Uni group today.
Yavuz isnt there for a few days but I spoke with one of the guys and he said he is not sure if the Redline will make a difference. And its $120 per litre and will need approx 2 litres of it + will cost $50 to put it in.
Might just live with it for now, until it gets worse.
Hello fatz, Thanx for the info.
Looking at the oil thats in it, the receipt says its 2.5 years old now.
And ive noticed that it only happens around 15 mins or more in to driving. When its cold it doesnt seem to do it.
And I have been doing gentle shifts, it still resists very slightly but no massive crunches.
Thinking about giving the shockproof a go because im thinking when oil gets warm, it thins out. Maybe this is why it doesnt happen when its cold?
Hi there, Is it weird that it only affects 5th?
Ive seen JustJap have a whole gallon of shockproof for $99. I might just grab some and do it myself.
I'd risk $100 and try it out and maybe get no result - just 2 feed curiousity really. But i cant afford to risk the $300 it would cost to take it 2 a shop to have done.
No it is very common to have 5th and rev play up first on many boxes as it is the furtest from the centre plate.
There are a few online stores you can get the redline oil from cheap per quart.
Hi, I am going to get some redline shockproof.
Noticed that there are 2 types - lightweight and heavy. Whats the difference?
Which one should I get for my car / problem and how many litres / quartz would I need? Thanx heaps.
Thanks for the clarification David. I was going to go with the heavy as it states its for problematic gear boxes and mine gives the slight crunch and resistance.
http://www.redlineoil.com/product.aspx?pid=44&pcid=8
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
