Got the car running tonight. Took it for a run with the bleed valve fully closed and boost was definitely peaking at about 7psi (assuming the halfway point on the boost gauge is 350mmHg as the max is 700mmHg). How do I tell if I have an R33 actuator? What kind of problem could be causing such a low peak if I do have an R32 actuator? Is it likely to be a leaking line to my boost gauge?
Any ideas guys? I recall the guy I bought if off saying it was restored to the 'factory' boost of 7 pounds by a tuning shop, could they have changed something? I have ordered a turbotech and pretty keen to nut out this issue so I can use it.
Moved my aftermarket boost gauge so I could see it properly and did see a peak of 0.65 kg/cm2 (nearly 10 psi).
Both my dash gauge and aftermarket gauge are hooked up to the intake manifold not the turbo itself, how much higher would the boost be at the compressor?
Did a test where I disconnected the t-piece which connects both gauges to the manifold and the aftermarket read 0 while the dash gauge was reading about 100mmHg vacuum, I guess that shows which one is to be trusted.
Don't worry about it. At the power levels you're making (ie essentially standard) the extra boost at the compressor is well within safe limits* when you're at 10 psi at the plenum.
*safe limits is a rubbery number of course because some standard turbos will let go at standard boost, and some will last forever at 14psi at the plenum - when 14 psi at the plenum could mean that it's more like 16 at the compressor. It's impossible to completely re-assure you, but it's unreasonable to try to scare you or let you scare yourself at the boost that you're at.
My 3 R31 RB20s all ran 7psi stock.
Nics red top
ECCS redtop stock turbo.
ECCS redtop RB25 roller turbo
Ran the ceramic RB25 turbo for 11 years at 14 psi, never a problem.
The Turbotech is a lot better than Turbospike sorry smart or bleeder type controllers.
With your setup 12psi will run forever.
Even my RB20DET-R ECCS redtop with a stock bunch of bananas manifold and TO4E turbs ran 7psi stock.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
