Got the car running tonight. Took it for a run with the bleed valve fully closed and boost was definitely peaking at about 7psi (assuming the halfway point on the boost gauge is 350mmHg as the max is 700mmHg). How do I tell if I have an R33 actuator? What kind of problem could be causing such a low peak if I do have an R32 actuator? Is it likely to be a leaking line to my boost gauge?
Any ideas guys? I recall the guy I bought if off saying it was restored to the 'factory' boost of 7 pounds by a tuning shop, could they have changed something? I have ordered a turbotech and pretty keen to nut out this issue so I can use it.
Moved my aftermarket boost gauge so I could see it properly and did see a peak of 0.65 kg/cm2 (nearly 10 psi).
Both my dash gauge and aftermarket gauge are hooked up to the intake manifold not the turbo itself, how much higher would the boost be at the compressor?
Did a test where I disconnected the t-piece which connects both gauges to the manifold and the aftermarket read 0 while the dash gauge was reading about 100mmHg vacuum, I guess that shows which one is to be trusted.
Don't worry about it. At the power levels you're making (ie essentially standard) the extra boost at the compressor is well within safe limits* when you're at 10 psi at the plenum.
*safe limits is a rubbery number of course because some standard turbos will let go at standard boost, and some will last forever at 14psi at the plenum - when 14 psi at the plenum could mean that it's more like 16 at the compressor. It's impossible to completely re-assure you, but it's unreasonable to try to scare you or let you scare yourself at the boost that you're at.
My 3 R31 RB20s all ran 7psi stock.
Nics red top
ECCS redtop stock turbo.
ECCS redtop RB25 roller turbo
Ran the ceramic RB25 turbo for 11 years at 14 psi, never a problem.
The Turbotech is a lot better than Turbospike sorry smart or bleeder type controllers.
With your setup 12psi will run forever.
Even my RB20DET-R ECCS redtop with a stock bunch of bananas manifold and TO4E turbs ran 7psi stock.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
