Originally posted by JiMiH
heheh yeh I believe you ... the same thing happened to my girlfriend's brother.
These ones are the real deal though ... they make you up a new numberplate.
I'm thinking I might order one first and do a little evaluation of it .. then if it's good I can recommend it to you guys :D
Otherwise if they're **** everyone will be a bit pissed!
I've emailed the people again ... now just waiting for a reply. Also sent a photo of a WA custom polycarbonate number plate.
Being a Guinea Pig is always good for the masses:-)
Well if you find it suitable and get away with it I'm in!
AHAHAH!! :lol:
Yeah yeah well talking about the stuff smoking in my little yellow school bus i was going to actually tell you guys that the Drum and Bass tune i was listening to had the exact same beat as Revn211's avatar mul leaves IT WAS FREAKN ME OUT! it's like they were dancing for me!
Now guys before you ask I'm not on drugs but it was sooo funny watchin the leaves on the avatar move at exact same speed as the tune i was listening to! It's like they were bopping with me :D Anyway i was half way writing it then i thought "nah they will think I'm to weird and on the whacky weed" so i didn't post it, so theeeen i pressed the back button a few times and it said your message is now being posted BLAH BLAH BLAH!
and it posted the bloody message from 13 mins before hand .... DOH! :confused:
and THAT guys is why the salt is in the sea...wait different story.... that is why i posted twice :uh-huh:
Originally posted by osc@r
Speed cameras...now here's a subject that sh*ts me to f*ing tears.
Do you know....
speed cameras in the UK are now being placed ONLY on black spots (2 or more road fatallities),
______________________________________________
Thats bollocks I have just arrived back from the UK and have a video of 8 gatso's (speed cameras) in under one mile of road!
Over there they actually vandilise them as a sport :uh-huh:
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
