When injectors get clogged/dirty they lose their factory spray (mist) and turn into a leaky tap, could explain why it's running rich.. no way to know for absolute sure unless the injectors are taken out and cleaned&flow tested.
There has to be a reason why there is excess fuel being dumped in, someone has suggested looking for a Atmo BOV which would cause the car to stall while slowing down and running rich (metered air being dumped to the atmosphere before it reached the engine instead of being re-circulated as the stock ecu expects).. although you would know you have one by the wanky noise.
  • Replies 49
Stock Bov mate. had a talk with the old owner who had her for 7 yrs. He reckons that it would be the AFM because it went faulty on him once and caused shit fuel economy but said it was doing its thing fine. But i suppose the injectors would be due for a clean, or would it be worth getting newys. Thanks mate for the suggestion wouldnt have bothered getting injectors done if it wasnt for your input. Ill get quotes tommorow :)
Yes cal my driving style will contribute. BUT my mechanic has had all his scan tools on there and the car runs very rich that is the problem. i had to fill up to the brim twice coming back from Melbourne so a 500k trip this was full to empty each time.
No I mean AFR.
AFM Voltage is irrelevant for me because it doesn't determine how much fuel the engine is getting at a certain point. It merely tells how much air is coming in to the engine so the ecu can work it out
If your hitting 5v at WOT then sounds like your maxing out the AFM anyway
to op, my story:
for the last 1 to 1.5 years i've been getting around 280 to 320km a full tank (60 liters) so thats's 18.75 liters/100km, i've just changed my fuel filter and now i'm getting 390-440km a tank (so i've wasted so much fuel this last year because of a dirty $20 fuel filter). Just from changing my fuel filter my economy is from 18.75 liters/100km to now 13.63 liters/100km. so if you haven't try changing your fuel filter and see how that goes. good luck.
fuel pressure was fine he tested it. he would clamp the hose and the pressure would go really high indicating a good pump.
Then he had a gauge connected. What did it read? Just because it has "good" fuel pressure doesn't mean it has "correct" fuel pressure.
he said not to bother as they were working when it comes to injectors. they were working fine apparently and the problem is running rich
If the injectors are dirty, they can hold the needle slightly open, allowing too much fuel to enter the engine. Result = RICH. So, are the injectors clean and flowing correctly?
I said it my first post, put it on a dyno and check AFR's, AFM voltages wont tell you the full story. For the reasons that have been listed in the post above plus many more, everything could be alright on paper, but your car is running Rich and causing bad fuel economy. Take it to a tuner and ask him to put it on the dyno and check the AFR's
Sensor voltages are really just inputs to the ECU, 4V at the AFM doesnt mean its going to put X amount of fuel into the engine.
I've recently just replaced one of my O2 sensors, and my fuel economy has increased by a huge amount. :rofl: So will be checking them on a regular basis.
I read online that having a faulty O2 sensor, you can use up to 30% more fuel. :rant:
Yep, I recently replaced my O2 sensor with a cheapish one from Vulture Motorsport.
http://www.skylinesa..._gopid__6063325
Also reset the ECU. Economy went from 300 km / 45L = 15L / 100km to 400km / 47L = 11.75L / 100km.
Definately worth trying this. Cheerin'. :D
After a few weeks I cleaned the AFM, which didn't seem to change economy but it did stop an issue at 10psi boostin' time.:w00t:
Edited by Not a Pulsar
yeah at light load the o2 sensors make the car run at around 14.5:1 AFR, if you unplug the o2 sensor, at the same throttle load it will run richer at aroung 12:1 AFR
I have recently lost my job so fuel economy isnt a problem because im on the bike at the moment. but from the sounds of it my goal is new o2 sensor and then get it on the dyno. i have done the fuel filter recently and no avail. Oh and most importantly injectors checked out
Coilpacks wouldn't make to much difference on fuel economy (unless they were colpletely wrecked)
Most of your fuel economy comes from your lean cruise cells which don't require a strong spark. The coilpack issues mainly occur under boost/load when the spark needs to be strong
Having said that splitfires are good for later on when you decide to start modding more
lots of talk of the AFM being faulty or having the right voltage but have you cleaned the AFM??? i dont think ive seen this mentioned yet...if so, sry i missed that. if your running an oil charged pod filter, they like to make AFM's dirty.
check for an air leak?? maybe in or near the TPS ( random idles are often this)
good luck...i couldnt imagine this sort of economy. the all wheel drive i guess would make it a bit more than a 2WD, but not that much...ouch. i get 400-500 out of my 33 GTST tank. 400 is with happy driving and happy laps. 500 is on the highway with my economy sponge installed :whistling: (i have seen 600km out of a tank)
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
