if the o2 sensor does nothing or its still bad afterwards check:
coolant temp sensor - the 2wire one, can be replaced with any of the same colour
cam timing - my 32 was a tooth out, didn't realise and wondered my the rb20 was such a pos, the ppl i sold it to worked it out and it goes wicked sick now
also, i think i got about 700 out of a tank once with my turbo brick, but my tank holds about 65 litres
just change the motor for an rb25neo
  • Replies 49
Hey the afm has been cleaned and im all very jealous of your fuel economy, i had a chat to the old skyline owner and he said his fuel was about 350k to a tank and it went down to about 200k once and it turned out to be the afm. He suggested replacing it with a new one and do the O2 sensor. The coolant temp sender does work but seems to read a little low so i will change it. what ones work ? the reason my mechanic is finding it so hard to diagnose is it runs well and goes hard. He says most fuel economy issues are with cars that run crap. Im going to get a mates r32 on the scan tool as well and do a compare on everything. Ill also get the injectors tested soon maybe thats why the idle hints slightly because its getting an irregular spray of fuel
you say the temp reads a little low, now issues with the clutch fan? my little bro's 32 had a stuck clutch on his, and it made his economy bad. but having said that his car was slow and loud and cold because of it.
hey guys as far as i can tell the ecu is stock. my clutch fan is in working order and from the sounds of it injectors will appreciate a proper clean :) ill keep you posted. Thankyou everyone who has contributed to this topic. I have just scored a job and it seems like its going well. Oh and got a 8 week payout for un fair dismissal :P The first things i will do with my first pay check will be an O2 sensor and MAF these are the one im looking at. probably like most im looking to spend the least amount of many but still get semi decent stuff ( I know thats near impossible ) This is the o2 sensor can anyone confirm if it fine for rb20det as it says rb25 but apparently they are the same
http://www.ebay.com.au/itm/NEW-Nissan-R33-Skyline-NX-N14-N15-Pulsar-Oxygen-Sensor-/150616354975?pt=AU_Car_Parts_Accessories&hash=item23116f309f#ht_2856wt_1270
And the MAF ( cheaper through the US because the aussie dollar is so strong)
http://www.ebay.com.au/itm/NEW-MASS-AIR-FLOW-SENSOR-MAF-89-95-SKYLINE-R32-R33-JDM-/400203344207?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d2dfa694f#ht_2925wt_1270
what do you guys reckon ?
I wouldn't touch that AFM, looks too cheap to be true, and who the hell is "AIP Electronics". There's no gaurantee has the exact same calibration as a genuine JECS made AFM.. I would only go with genuine AFMs made by JECS
i'd try re-soldering your current afm before you try that one
maybe unplug your o2 sensor for a tank and see if you get better consumption
and deffinately get onto that cool running (check thermostat too? you can run an r33 one but its 82dec not 87 like r34's run)
in the tridon book it says 82
but i got a nissan r33 one with my timing belt on it and it said 76.5 i think
both run at about the same temp tho, so maybe they rate it differently (opening vs fully open?)
  • 3 weeks later...
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
