Well it's come time to sell my Stagea
Its a june 2000 Build C34 Nissan Stagea, 93,000km and still has a couple of years left on its warranty
It has the Full Dayz bodykit including the carbon insert in the front bar, carbon mirror covers, carbon "d" pillar covers and taillight covers
Engine is still the standard RB25DET Neo, running standard boost control and just a Blitz pod filter
It has a 3" bellmouth Dump pipe, 100cell Stainless highflow cat and a full 3" system finishing in twin 3.5" tips
Auto trans has been fitted with a shift improver kit by MV autos and had a full service and attesa bleed
The tiptronic shift on the MOMO steering wheel is awesome
Rolling on 18 x 9.5 +20 Enkei rims with brand new tyres, Whitlen adjustable rear sway bar and R33 GTR dampner adjustable front shocks
Fitted with a 1250kg towbar it bulls my boat with ease. Great family car, fun car thats practical but still surprises some at the lights
$15,499 ono
I can remove items to make it cheaper, I still have all the standard parts in the shed (ie rims, sway bar, quiet exhaust, compliance cat, shocks,etc)
Pm me for further info
https://www.sau.com.au/forums/topic/379515-sa-c34-dayz-stagea/
also has dual electric sunroofs, electric tailgate latch(self closing), power windows, power mirrors, climate control
car Has been serviced every 5000km since i have had it, new fuel filter and iridium plugs went in the first week i got it at 56,000km
  • 3 weeks later...
mate if this thing is still up for sale start of next year ill be on it like a fat kid on a cupcake. just not in the position to snatch it up right now.
Had one offer of $10g plus a 32 gts4, which i will sell straight away just waiting to see the dollarswhistling.gif
still open to offers, no deposit taken, need it gone, i gotta pay for my chevy truckthumbsup.gif
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
