hey everyone about to start a rb26dett r33 gtr v-spec build. i have got so far.
3.5 inch exhaust
3 inch dump pipes
apexi air pods
splitfire coilpacks
boost increase to 14psi
tomei 260 type b cams
tomei cam gears
haltech platinum pro-plug in
any recommendations on where i should be going after this.... aiming for atleast 450-500WHP
https://www.sau.com.au/forums/topic/379561-gtr-r33-v-spec-build/
definitely going to need to change your std turbos, as stated -5 or or even -9 will make 450hp, depends what kind of package you want (response or overall power)
stock bottom end will also hold your wanted power level, question is for how long....
Bottom ends still standard. I've heard there pretty good for around 600 hp is this true?
Well you do realise 600hp is pretty close to 500rwhp yes?
So if you've heard they are "good" for 600hp, and you want as LEAST 450-500rwhp - you'd certainly be pushing things gonig by that.
That said there is no magical "safe" number for power. Depends on the age of the motor, use of the car, previous life (generally unknown), tune etc etc. Basically how long is a piece of string.
End of the day i use a rule like this.
Can you afford to break it and the associated rebuild (AKA: The $10,000 adventure)?
If you answered NO - stick to Garrett -7s or -9s with 300-330rwkw (400-450rwhp)
If you answered YES - go for bigger Garrett -5s or a GT3788 370-400rwkw (500-550rwhp)
Ok thanks for the advice really appreicate it. What do most of you's decide with turbo upgrades.
1. Stay with the twin turbo set up
2. Single turbo set up
Could you please state your reasons why you decided to go which way.
Thanks again
Edited by Rumpig
Im pretty sure you have to make that decision for yourself mate.
Just ask yourself basic questions
What do you want out of the car?
Dyno Queen?
Response machine?
Good power with good - average response?
Me for example, I will be going -7's because I want response and car will be mainly street driven. And they will get me where I want to be until its time to rebuild :).
Google search is there for you.
Im running a GT35 single on my stock rb26 with poncams, safe/conservative tune on 20psi is netting me 485hp at all 4 hubs. So thats around 450rwhp. Could push 1-2 more psi but im happy with the power!
I was running a pair of -7s and i was struggling to make over 300kw without pushing the turbos too far (21psi) on the same dyno. Only difference was stock cams.
Single > -7s. Cant comment on -9s but im told they are quite similar in terms of top end power.
I rather make a comfy 450rwhp on a big single as compared running a pair of -7s or -9s to their limit to reach 450rwhp, which i doubt u will get anyway.
Also, the single setups are easier to work on.
Oh and im getting better response with the GT35 as compared to my -7s too :)
The only reason why I would consider sticking to twins is to retain the "stock" look but tbh, the benefits of the single outweigh the want for the stock look, big time.
Cue, single vs twin debate....
If im reading your comparo graph right... Your -7s were only making 220rwhp (165rwkw) @ 4500rpm ?
If this is correct, then you had an serious setup issue. Possibly boost control.
You should have had a result around 350rwhp (260rwkw) @ 4500rpm. Quite a whopping difference to say the least.
A correct/working result would actually the -7s more responsive than the single. Given a GT35 is larger than a set of -7s, that makes reasonable sense in the broad world of comparison with this type of thing.
So not really a fair of debate single vs twins if you are comparing a working set-up with one that isn't working :)
Fact; 7's wont make 500rwhp.
Fact; Most -9 results also fall short of 500rwhp, well sorted engines (read: big dollars spent) get close 350rwkw
To the OP: all the info is on here that you're asking for. 5's are the turbos to get you the hp you want without any unrequired spending or making your car an easy target for police.
Dyno Queen?
Response machine?
Fair call, it is possible that something was wrong but im done thinking about it, the turbos were fine when they came off, the acuators were checked twice, correct preload, balanced while on dyno etc so im not sure what else could have been the issue.
An interesting comparison would be between a pair of -5s to a GT35 setup.
21psi is "too far"?
LOL
Not being rude, but that made me laugh.
I didnt say 21psi is too far.. I Re-read what i wrote, i see how u mis-read that, my bad.
I made 300awkw at 21psi (bleeding off to 18psi at redline) with my -7s. This being my personal experience, i am certain that if you want to hunt for the power level that the OP is after, they -7's will be pushed way beyond their effeciency range (too far). Hence why i said that -5's would be a better choice over -7s or -9s.
All of my tuning ventures have been on 98ron fuel so forgive me for being more conservative than you eastern staters with e85. Yes im jelly that you have it on pump and we dont but we shall not go there :)
I always use 98 when posting stuff, as do most, kinda a given.
Usually people post/make note of E85 when used.
-5 and GT35 would be much closer/interesting I agree.
Pity you -7 setup was down nearly 100kw at 4500 tho, would've really been crappy to drive!
Yeah i know! I grew tired of the lack in response and top end power although the mid-range wasnt too bad but now my car is making good power everywhere so im happy and not complaining :)
If anyone has a gt35 vs -5 comparison on the same dyno please share!
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
