  • 4 weeks later...
I have been running a switch on my r33 chuki for about 4 years or so with no problem , I run the switch through the 4wd fuse in the boot fuse box, just take the fuse out take it apart and replace the 2 standard spades inside for your own with wires attached ,stick an inline fuse in of the same rating and run the 2 wires to the centre consul and fit a switch,,if your in 4wd you can switch on the go ,takes a minute or so for the line pressure to drop then the 4wd light comes on and your in 2wd.
You still have to turn the ignition off and on to reactivate the 4wd.
I'm running a full 5 gear OSG cluster with strengthed input and excedy twin plate.
  • 1 month later...
http://www.rhdjapan.com/hks-kansai-active-e-ts-attesa-controller-nissan-bnr32-bcnr33-15041
Has anyone used this controller? I need to put my 33 GTR into rwd for the drags, looked at the Full Race ones but they aren't for v-specs and the
Ruzic ones don't go to full rwd. This is the only other one I found so if anyone knows about them your help would be much appreciated.
Anyone can take a photo of this said "plug"? I am trying to locate it but theres too many!
In my S1 Stagea its behind the drivers side kick panel : a very small black plug taped to another loom with a single yellow wire with a green trace going to the plug and a single black wire going to the socket.
Hmm.... so you're saying the plug wire colour is different to the socket wire colour? WTF is Nissan thinking but if thats the case, shouldnt be too hard to trace.
I'll have a look for that and hopefully its the same for the 33 GTR in terms of the colours. Cheers.
  • 2 years later...
  • 3 months later...
Hi all
I'm trying to locate this plug but am unsure which one it is.
Is it the brown one attached in this picture.
Cheers
Most likely. Here's how I described mine when I saw it:
In my S1 Stagea its a very small black plug taped to a loom with a single yellow wire with a green trace going to the plug and a single black wire going to the socket.
You will soon know when you disconnect it. If the car explodes in a ball of fire its the wrong one.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
