ur questin is too vague, real question is how much $ u got.
i
cheapest bet is:
$1800 na s13 weld diff 2nd hand coilovers total = 2.5k max and its licenced for street.
dont do it in your R34 as it will just end up a real pig. start off with a real piece of crap and see how u go. if u wanna fork out a bit more get a turbo r32 skyline or sr20det s13 but ur looking closer to 4-6k. turbo is more power and easier sideways action, but also for a 4-6k turbo skyline/silvia i wouldnt put too much faith in it ie BOOM
Edited by Char
https://www.sau.com.au/forums/topic/379705-driiifing/#findComment-6054739
yikes, should have bought my friends r32 rb25det few months back :) would u want it to be able to be driven on the street or for track only?
either way im sure you could easily find a nicely 'already modified' skyline, silvia, 180, or s14 for that much money all ready to go nothing more to pay (except tyres) :P
basically the way it should work for around 10k+ is the older the model the car the more modified it should be, ie an R32 or s13 for sale at 14k would have to be built or atleast have a big turbo slapped on the side with some good suspension, rims, ecu etc as opposed to an s14/s15 or r34 at 14k would be less modified or not modified at all.
you dont have to stick with nissan either, you can look at mazda rx7, toyota, people drift all sorts of cars, you cant really say this car is better than that one, some people say 4 door cars are better some say 2 doors.
its just personal choice
tho usually for a beginner you want to start off with something with just some good suspension setup an lsd diff and not crazy power
Edited by Char
https://www.sau.com.au/forums/topic/379705-driiifing/#findComment-6054781
yea im not to keen on the r32's unless its a 4 door, this is my mums accout so shes the one wih the r34, i got a 33 but i was gonna drift that but its to clean and straight to do it in.
i think i would go with a 32, 33 or 34 4 door :)
so what car would you recomend char?
https://www.sau.com.au/forums/topic/379705-driiifing/#findComment-6055089
build your own....
s13 shell or 14
sr20 outa an s14 or 15
RB25 Gearbox and jim berry clutch
6boost manifold GT3076 turbo + gate
800cc injector dynamics injectors off ebay (US)
PFC + Boost controller electronic then into shaun at allstar for a tune
Surge tank setup with bosh pump 040 and 044 + Braided fuel lines teflon
coilovers plus steering spacers hicas weld with welded diff ajustable upper rear arms...
E42 race fuel or bp98 if its a streeter
good compedative platform that can be very fast im thinking 370-400 hp
https://www.sau.com.au/forums/topic/379705-driiifing/#findComment-6055387
bahaha pete. most important is suspension setup and tyres.
s14, has better brakes and five stud. great platform for drifting once you drop in a 25 neo or VH45DE
Or a VK45DD OR a 1GZ-FE :thumbsup:
https://www.sau.com.au/forums/topic/379705-driiifing/#findComment-6055695
build your own....
s13 shell or 14
not a toyota sprinter :( lol
ill either go r33 or s14 with the same sorta set up that mike (blitz1) has said :)
https://www.sau.com.au/forums/topic/379705-driiifing/#findComment-6056311
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
