RB25DET. I would if I could.
Depends on how much the car is gonna cost me.
I gotta pay insurance, etc for my Camry too.
The way I see it, is Turbo = $$ insurance for 18 y/o
Save money from the insurance, add nice
sound system, bodykit and possibly turbo conversion in
a few more years.
https://www.sau.com.au/forums/topic/37971-new-member-here/#findComment-764753
I'd get a r32 gtr. r32 are cheap and fun, I got a r33, and its nice, but the series 2 is what i'd go for, mainly for the extras. and they going to be mainstream shortly.
also welcome.
First of all welcome Eug.. If you are looking for a r33, get a series 2 like Zoix said coz the series 2 looks much better stock than the series one stock. ;)
I only recently got me car.. so check out www.carsales.com.au, www.carpoint.com.au and also www.tradingpost.com.au. There was quite a few 33s, when I was looking for a skyline as well.
On top of the mentioned sites.. do a search for import car yards in yellowpages.com.au most of them also have websites that is slightly out of date...
If your 18.. the insurance for a GTST will cost you an arm and a leg.. but some people can still afford it... :|
Last but not least.. Colors is not a major factor (it can be changed relatively easy), probably better off looking for one that you can afford that is in good/reasonable nick with good engine and things.. :D
Just my 2c worth. Good luck to your car hunting dude and once again welcome.. :wavey:
https://www.sau.com.au/forums/topic/37971-new-member-here/#findComment-765631
As always I use my trademark welcome line:
"Welcome to your new addiction!"
Yeah they are coming out of the woodwork, must be all those l337 looking fliers I have been littering all makes and models of skylines with :)
https://www.sau.com.au/forums/topic/37971-new-member-here/#findComment-766008
haha, yeh I managed to find my way thru all the
headings and titles n stuff.
No rush John, I'm still lookin - I found auto terminal
heading down there next week, and down to G/Coast
to look thru the import yards.
no R32 for me R33 all the way.
What's this i hear about you smoking glow mushrooms,
killing owls and eating out 14 y/o hookers?
or sumthin like that. :D
yeh friendly guys! hope ta see u all soon in my
skkkyline!
-Eugene
https://www.sau.com.au/forums/topic/37971-new-member-here/#findComment-767541
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
