Hey Guys,
So i just brought a R33 GTST with a RB2530 in it, the wedge holding the harmonic balancer has come loose and stuffed the crank so im in the process of replacing the crank. have the other one getting balanced etc..
so before i started pulling everything down i had the motor at TDC, but after lossing the flywheel bolts i have turned the motor almost half a turn without realising.
THEN i removed the timing belt without marking it on the belt,crank or cam gears.
so now i have the belt off and the tdc markers on the cam gears facing: inlet: 4PM outlet: 8AM
just woundering if i should re install the belt?then turn the motor to TDC?
No need mate. There are dots you line up on the crank, and cam gears. Just line all the dots up and slip the belt on.
I urge you to check it 10 times and have a smart mate look and see if the dots line up good. I had my iPhone down there taking pics of the crank dot because you can't get your head down there to look at it straight on.
Once all the dots are lined up, slip the belt on and problem solved.
You shouldnt really use marks and hop it goes on in the same place anyway, that's just being hopeful, and not good practice.
If you are srtipping the motor why are you worried about TDC?
i am just changing the crank so i didnt want to pull the head apart. i guess ill take the rocket covers off and just put the cams at TDC before re instaling the crank.
so is there any marks on the crank for TDC?
do i use the key wedges for the pulleys or is there marks on the pulleys them selfs?
sorry for the noob questions just wanna make sure things are right,
thanks
DAN
Just use a dial indicator to find exact tdc with number 1 if you have one. Or use the marking on the timing gear to line up with the notch in the oil pump housing. Then use the cam gear dots to line up with the markings on the timing cover backing plate.
Usually tdc is is when the key slot for the woodruff key is facing up.
Or be dodgy like me and use a pen down the #1 plug hole to get it as close as possible and adjust to get everything lined up.
I dont suggest that method though...Dial gauge is much better
no need to take the rocker covers off, just leave the cam gears on and line the dots up to the marks on the rear timing cover. if you turn the crank roughly 60 degrees past tdc you can turn the cams without any risk of piston to valve contact
Whip the cams out and then spin the crank to your hearts content, that way while you are putting the engine back together you don't have to worry about any unforeseen piston on valve action.
Edited by D_Stirls
did your old rb30 crank have a collar fitted?
if so can you take pics of the snout of the crank of the new crank and the old one.
I might be able to pinpoint WHY this happened and save it from happening to you again a second time. Changing the crank and not investigating WHY it happened is not the right way to go about it if you don't want it to happen again.
let me know if you want my help.
thanks guys!
im getting my new crank back on wednesday, then ill get you some pics guilty.
what do you think could of been the cause?
Edited by BMYHOE
i have an idea.. and it happened to me before....
crank bolts DONT come lose on their own.
just make sure you send me the pics before you put it back together. pm me if i dont see them straight away.
thanks guys!
Sorry mate been busy ...
this is the f'd crank
post-59990-0-37536900-1320148560_thumb.jpg post-59990-0-00373000-1320148636_thumb.jpg post-59990-0-28313800-1320148660_thumb.jpg
this is the new crank
post-59990-0-44339300-1320148739_thumb.jpg post-59990-0-15828100-1320148784_thumb.jpg
i didnt get any more pics of the new crank, hopefully that will help you.
we think that this was all caused by the harmonic balancer bolt coming loose..
Edited by BMYHOE
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
