Doesn't actually sound like you've hit the cut as yet as in my experiences with boost cut on my R32 GTSt, it's quite violent....ie. you'll know when you've hit it.....Forget falling back to 12psi, you lose all power until you take your foot off the accelerator!! You can get a fuel cut defender to stop this, Turbosmart make one specifically designed for the R32 RB20DET:
http://www.turbosmart.com.au/fuel_cut_defenders.htm (see bottom of the page, I have one and can verify that they work...bit touchy to tune tho!)
Sounds more like your boost control setup and/or the wastegate not being unable to hold all the way up the rev range.....For reference, I used to run 16psi through my steel wheeled R32 turbo without any falling back even at 7000rpm, but that was using a solenoid controlled bleed valve.
Also bear in mind the ceramic turbo tends to fail fairly quickly at these kind of boost levels.
https://www.sau.com.au/forums/topic/37977-rb20det-boost-cut/#findComment-764960
Hey guys,
doglet - You're telling me mate!! I thought I'd f**ked the car right up first time it happened!!
VLRB20DET - Presuming you're using the R32 RB20DET ECU/Airflow meter and not a custom setup, you will be able run the Turbosmart fuel cut defender I gave a link for earlier, worth about $200 if I recall correctly.
Some useful info about FCDs from my personal experience - the boost cut occurs on the RB20DET when the voltage coming from the air flow meter to the ECU exceeds a particular value (5.05V?), what the fuel cut defender does is clamp the voltage seen by the ECU from the air flow meter to an adjustable amount, usually just below the cut voltage....So just be careful if you do get one as they can lean out the fuel mixtures too much in the upper rev range if not adjusted correctly, many tuners view them as a bit of a band-aid solution and prefer to modify the ECU to remove such cuts....more expensive though!
https://www.sau.com.au/forums/topic/37977-rb20det-boost-cut/#findComment-766073
It's up to you man, the FCD was okay on mine until I started fiddling around with new mods, at which point - like I said, it was touchy to readjust. With a different turbo bolted on, you're likely to see more decent, reliable power gains from either a modified/dyno tuned RB20 ECU or an aftermarket job such as those you mentioned, and yeah another major benefit is then you can set boost/rev limits wherever you want, but it all depends on what you can afford.
https://www.sau.com.au/forums/topic/37977-rb20det-boost-cut/#findComment-766107
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
