Just making the thread again because the old one's first post was battered and I couldn't find the edit button?
I recently bought a 180 from a guy off another forum, and I think I may have financially put myself in a bit of a mess with all the shit going on at Qantas at the moment (employee).
The car itself only has a few tasteful mods, done for the better of the car. It's pretty much buy the car and all the good stuff are done already!
BODY
White
No major dings or scratches
Amazing condition for its age - Pics don’t do it justice!
Professionally rolled rear guards, no cracks/rust.
INTERIOR
Perfect condition
BLITZ turbo timer with boost warning
BLITZ boost gauge
180sx genuine floormats front and rear
No broken plastics or missing pieces as is common with other 180's
WHEELS AND SUSPENSION
BC Adjustable Coilovers and damper w/ C-spanners. 1 year old. Cost over 1,400 brand new
17x8.5 TE37 style wheels.
ENGINE
Compression tested at 155psi averaged over all four cylinders 3 months ago.
Serviced every 5000kms, receipts to prove.
Still running standard boost @7psi.
S15 T28 turbo (was told by previous owner that it was a ball-bearing... Not 100% sure as I don't know mechanics of cars that well)
Stainless exhaust turbo manifold - heat wrapped
Full exhaust system - dump pipe+hi-flow cat and 3" catback. Sounds really good, no drone!
Dual core 52mm aluminium radiator
GKtech 'No-HOLE' front-mount intercooler kit (100% legal as battery tray hasn't been cut at all)
Braided oil and water lines.
GEARBOX
Excedy heavy duty clutch, bites great
Short Shifter kit
SECURITY AND SOUND SYSTEM
REMOTE Central locking and immobilizer
Pioneer Headunit
Pioneer front and rear speakers
Pioneer tweeters installed in door professionally.
STANDARD PARTS (included in sale)
Genuine Nissan steering wheel
Standard suspension setup (front/rear)
Standard sidemount intercooler
Factory intercooler piping
Other than that, the car has been very well maintained throughout, inspections welcome. Has 186,000 K's on it, and given the way the car drives and feels, you would think it has less. The car had a roadworthy done under a month ago for being too low, it's now been raised and should have no drama's at all getting a roadworthy
Only selling to throw a little extra cash onto the mortgage in case the worst happens.
Honestly, for a car built in '94, this thing is the goods. Come check it out, inspect it, drive it, buy it, enjoy it.
$8,500 ono
Contact Manny on 0488582587
Edited by stawka
https://www.sau.com.au/forums/topic/379770-1994-blacktop-180sx-vic/
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
    • Yep, agree with all of the above added on too. I just love the age old "what boost were you running?" Question without getting any other surrounding data. IE, may have ran 20psi, and lived for 12 years, but it was an 80 year old granma driving it to Bingo once a week and never took it over 2500rpm.
