Hi guys,
Looking to start building a 25/30 (my first one) for my project in the next 2-3 months. First off I live in TAS, so there's no specialist mechanics and what not here for this kind of build (but there are good mechanics).
So I am doing as much research as I can before I start.
Yes I have read and looked over every 25/30 thread I can find on here and working on getting my head around it all =)
Am having a little trouble getting my head around the VCT / VVT and the whole oil pressure thing and what to do with my build. There are just so many different ways and methods on here that people have done and how to go about it that I am at a loss with what to do.
My 25 head is NOT the Neo model and has Tomei 270 procams, springs and lifters, new valves might be on the go too. Engine is running 950cc injectors and a Garrett T04Z turbo with Wolf 3D Ver 4 ECU.
My question is: what is your recommendation for the VCT? delete or keep? Oil Drain Back? etc.
2 links that have caught my eye are:
http://www.skylinesa...al-oil-control/
and
http://www.spoolimpo...d-oil-drain-kit
please have a glance over the first link at least for me =)
Would LOVE all the help, advice and feedback I can get =) Thanks much SAU
https://www.sau.com.au/forums/topic/379772-2530-head-oil-vct-help/
Tomei Procams are not designed/built as a VCT setup. In that case, no worries about oil feed for that. They are a reasonably large sized spec, and your cylinder head guy should do all the setup to ensure proper clearance between head casting and cam lobes once everything is installed. Solid lifter upgrade from the hydraulics would be advisable. Also valve spring upgrade to cope with the lift and not strike coil bind issues is a big one. You WILL need vernier cam gears to optimise cam timing.
There is value in drilling out the oil returns, installing oil feed restrictors, and doing something with the oil pump.
Running a T04Z there is the potential to make some pretty serious hp. Hope the build is budgeted to deal with a pretty serious upgrade to the reciprocating and rotating bits down low, balancing components etc and allow it to rev nicely.
Actually, when you look over the 30DET build guide, and a few threads in this section, I would think it's highly advisable to check approaches and results from others, and your own build plan and mechanical specs will become much clearer. GL and update as you go along.
Thanks Dale =) pretty much what I had in mind then, thanks for confirming =) and yes, will definitely be doing an oil pump upgrade and fully rebuilt bottom including rods.
"Actually, when you look over the 30DET build guide, and a few threads in this section, I would think it's highly advisable to check approaches and results from others, and your own build plan and mechanical specs will become much clearer. GL and update as you go along."
Good iea, I'll do just that =) Thanks for the help / advice
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
