  • Replies 45
Fairly sure its only a 20 but it does have a rather nice note to it
I give up on the f**kin media link shit just click on it :) Edited by chocco
Sounds similar to the car Steve speaking about. Not sure which i prefer, hard to get the exact from video but having seen the other car in person it was certainly the winner. Best I've heard in 10 years!
Stock 25 head, 3ltr, 6boost manifold with a gtx35. Not sure of the gate/exhaust combo etc.
Sound is as much to do with the manifold, exhaust, gate size, angle/length of screamer as it is RPM anyway.
You could rev to 9000rpm and it could sound shithouse.
That and the S15 with RB25 and the 35R (S15 had non GTX version). Winner.
Panik hands down for me, best sounding RB I have ever heard :)
Looks like a nice video bomb from Nathan Weissel during the interview there. Hard to tell if it's his stag but looks pretty damn close
The blue S15? Funnily enough one of my best mates... Plus all the piping was done by Clint Brown the one who built Panik haha
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
