Hey all,
I bought my cefiro about 3weeks ago. The bloke i bought it off installed the 20det motor himself from an R32. He said the temp gauge, rev tacho and window wipers all worked before the install and didnt after..
i just picked the car up from a mechanics who said it was the fact that the cluster is original from when it was non-turbo and signal sent from the turbo motor is different and the cluster cant read it properly. The temp gauge just goes straight up to 2/5 full and stays there and the rev tacho doesn't even flinch... He said if i get a cluster from a factory turbo ceffy it will fix the problem.. Same with the wipers, similar story but he said you could prob just get and auto elec to just re-wire it..
So im just after someone who has encountered the same problem and what they had to do to fix it, so i don't go wasting my money.
I'm thinkin of ringing some mechanics that do engine conversion on jap cars and ask if there've done many 20det conversions into ceffys and see if there've had similar problems and what do to fix it..
I've had a few mazda, previously but this is my first RB so im abit of a noob. Any help would be awesme.
Cheers jared
Hey champ, just put a r32 rb20det into my cefiro. You'll find the plugs that connect engine loom to body loom are different between r32 and cefiro. It's not the cluster, but where the wires go in the plugs. Basically need to identify tacho, temp gauge, wipers wires on cefiro plug, then identify on engine (r32) loom, join up. I was looking everywhere for the info, ended up getting a mate to help out. Can have a look and post the info up, prob on weekend. Where you at?
Hey mate,
Yeah sweet, some info would be bloody awesome. Sounds pretty simple, wish i was good with wires!!! hahaha
I'm in adelaide mate, western suburbs.
Thanks man, i knew someone on here would know what's happening.
Just out of curiosity, what ecu are you running?? Mine is running an A31 ecu with an 32 RB20 in it.
Also wanted to know if anyone has any pics they wouldnt mind posting up on where the ecu is installed. Cause mine is just lying on the passenger floor and i wanna know where it goes and which way it faces..??
Hope someonecan help. Cheers
It won't be the cluster at fault.
If you look at where the ECU is there should be a plug coming from under the dash board, you will need to find some wiring pinouts to identify the correct wires. Then you will find a plug coming off the ECU loom will have all the dash wires in it but the plug will be different shape. If you have the original cefiro loom you can chop the plug off and pop the wires in it, otherwise you will probably have to join them with solder or some other connectors.
As far as the ECU location, it is supposed to sit behind a plastic kick panel on the leftside of the passenger footwell.
Thanks for the reply, yeah i know now it def isnt the cluster... I may have to get some pics up cause where the ecu is their is about 4 other plugs not connected to anywhere. 1 or 2 of em im led to believe had to do with it being auto before... The others im not sure...
So you reckon i need to get the cluster out, check the wires that run to those gauge that dont work and then identify them at the loom end??
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
