i have cai + catback, high flow car, coilpacks, good tyres already
my exhaust seems to slow the car down or do you think this is pretty quick for an NA
no one knows whats wrong with it its a 2.5" catback with no mufflers but it does have a resonator
it makes a bang sound from first to second gear
http://www.youtube.com/watch?v=wczannAfOo4&NR=1
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056345
It could definately use a little more power IMO, SAFC + tune will open it up a bit.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056369
lightened flywheel often does bugger all for acceleration times, because while the car will speed up faster, it is also more prone to bogging down off the line. if you had a stupidly heavy flywheel you could fry the tyres by dumping the clutch at 1500rpm with bugger all throttle. if you have the worlds lightest flywheel (or no flywheel) you would nearly stall the car dumping the clutch while bouncing off the rev limiter if you had sticky tyres.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056441
SAFC got me sweet FA in terms of power, got it tuned, got a tiny bit of torque mid range and thats it. Not worth it.
Ended up taking it out the next day and selling it for more than I bought it for.
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056522
Extractors, 2.5 inch system Highfloww cat and a boxed off Apexi pod filter.
This car http://www.skylinesaustralia.com/forums/topic/348709-r33-gts-build/
Hmmm no idea why it wouldn't increase power, i know of several of them used on NA 300ZX's and the gain was a good 10-15rwkw depending on the car. Hey nice car btw, diggin the 1/4 mile result :thumbsup: Thats the quickest NA liner i've seen :happy::banana:
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6056621
higher dislacement thats why....
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6057520
Safc that can only alter air fuel on a n/a skyline with mild bolt ones is fail in gain imho.
And err, that seems really slow considering you have some bolt ones too. I've been in a friend's na 34 auto and it was stocker (is completely stock).
Maybe get the health of the engine checked out and make sure timing is ok before trying to make it faster. Heck, if there's something wrong and it gets found and fixed it'll be faster anyways lol
https://www.sau.com.au/forums/topic/379806-flywheel/#findComment-6058478
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
