i think you are over estimating the performance of a NA skyline. they are only a low to mid 15 second car
well yeah ive timed it and it did 0-100 in 8.2 which isnt too bad for it considering its age now lol and it does 8 when it came out of the factory lol but its done 123,000 k's now and hasnt had its timing belt changed yet so that would probably make a difference
https://www.sau.com.au/forums/topic/379806-flywheel/page/2/#findComment-6060269
