what determines the difference between major/minor?
or is it how they feel
Might be how they feel?
I got a major defect for being too low. The lowest point of my exhaust was 5mm off the required 100mm.
Had to get a RWC and spend $500 fixing shit up that other workshops reckon didn't need fixing....
Forever my car now will be a 4wd and I will not lower it...
From memory there is a box on the sheet where they mark it as minor or major and I think most officers will do major if there is a few items that need attention. When I got done for HID it was minor...assuming a sensible officer, major would only apply to things like a serious safety hazard or numerous engine modifications.
Cheers guys!
Yeah when my friend was taking out all the shit to get to the sparkies he kept on saying luckily I have this tool, otherwise if you did this yourself at home it would be a bitch for you to get 'x' screw out.
I get jelly when I hear my friend changes his spark plugs in his s15 in 5 mins.
You could change the spark plugs in my Calibra in 5 mins. East-west engine, with spark leads that just pull straight off the plugs...and there they are. Unscrew old, screw in the new.
I believe it is the third note.
Driven past any Highway patrol cars yet Aaron? :D
yep.
yesterday night.. didnt even look
3 days prior.. who actually put the window down and said "nice car.. good to see you not drive like a dickhead"
theres nothing to defect in my car now since i put a return flow intercooler in.. it wouldve been the only thing..
110mm high at the lowest point.
none of this HID stuff.
wheels sit flush with no poke..
i dont think engine shock braces are defective. or colour lol.
maybe exhaust is a little loud but that doesnt worry me. im changing that soon lol
that said.. i dont exactly expose myself. drive to work and back. sometimes, or to the missus house.. otherwise she drives her mobile.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
