Lol game over. I woulda pulled over and try to kill the f**ka.
If i couldn't find it then well it would be one paraniod drive on the way home....
Pulled over still half on the road and jumped the f**k out. Lost it for a while then found it on the back of the steering wheel. It ran a few laps while I tried to kill it with my boot, lost it again then eventually found it dying on my seat.
Woulda left the car there and reported it stolen if I couldn't find/kill it
orrite, bringing the "fail whale" kakimoto widebody for SAUNats... maybe. Gotta get a permit to drive it cos the trade plates are on compliance cars.
first time i saw that thing was happy cup meet in 07 or 06 at the first meet i had organised. was a nice surprise to say the least.
hmmm looks tlike the quarters are different, or could be the shadow?
def running spacers. those guards are rolled and pumped like a mofo.
this one time, i was driving home at night and i felt a tickle on my neck....ignored it.....tickle moved to my face. looked in the rear view, calmly pulled over like a boss, slowly got out of the car an FREAKED. huntsman on face.
driving with my arm hanging out the window something similar somehow landed on it while doing 80. luckily it fell off after a couple retarded spec arm shakes
Should have given that sucker a few right hands to the mouth.
Pic again?
cbf, wait till friday
damn straight. work hooks me up with qantas club and business class.
So coming up on Friday night?
yeah leaving friday at 4pm from melb. should be there by 7?
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
