I missed like half the wasteland crew haha. Stayed till the end, didnt notice when everyone snuck away. If i knew that every r32, r33 & r34 GTST/GTT was going for the same award I wouldnt have even bothered going up so early. What a jip!
Heard something about January or February? Not enough room to fit it into this year. Would be better weather then too, no icey roads on the way up f**k that was perilous last time.
This was my return to an SAU event for the first time since I sold my car, probably 2+ years ago...
Made me want another skyline asap....Responsible dez must take control though...Drove Sandra's car for most of the weekend though, so that helped
With the wheels up against the guards and excessively low ride height nothing will be particuarly nimble.
wont be fitted unless i end up with an ma70.. only then, id be tempted to bolt on spacers and run some stupid sized wheels
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
