csb bro Did he give his camry a boot?
We're you the skyrine that was driving behind me on springvale road when we were all heading home and I turned off a bit after Princes Hwy Saturday night?
yeah that was me. You turned off springy road. My friend lives on that street. I was going up to FTG road.
why u ask?
So Ex demo car 7K saving + 1 month earlier v New car
How much do they go for 2nd hand? Aren't ex-demo's generally thrashed? Correct me if Im wrong.
Also make sure the 'new car' price is the driveaway price, and does not have other hidden charges.
Do you have alot of time off work during the x-mas period and thats why you want it before then?
Not entirely sure on full price but they are around 70 new. Yeh I duno about ex demos that's why I'm asking for advice :P but I guess your right they have probably been thrashed.
No time off work until jan but yeh I just want one :P I think I'll just talk to a few dealers see what they say see if I can find a honest salesman if they exist
you put a brake line clamp on the soft line near the caliper to stop air get in/oil getting out, less of the system will need rebleeding when you reattach the calipers.
had a go at 1 of the rears top hose is a bolt bottom one there's nothing couldn't figure out how to pull it off so i gave up lol. will try again tomorrow...
haha yes I am winnar.. all you Westies/Northsiders = FAIL
Im using 10W40 Motul Turbolight in both cars atm and I think its burning off like a mutha :< GRR
as soon as I figure out htf to get the oil filter off the S15 (kjghgfhjgff!!).. I'm gonna change it.. again :<
I think the 8100 used to be better but then thats 0W40! Have been told at Nats that Turbolight is like water..
Agreed, Turbolight 10W40 was like water. Used to disappear on my SR20DET and RB25DET, both of which were healthy engines (the SR reasonably stressed and the RB babied but getting on in km's.) Wouldn't ever use it again. Both my SR and RB loved Penrite Semi Synthetic 15W60, both ran quieter, smoother, idled better, temps and pressures remained better. And you would drain basically what you put into it, no dissapearing acts here. I'd definitely use it again on a highly stressed or slightly older engine. Tried running the Cube on it, engines too young and tolerances are too good so it was far too heavy and consequently made the engine noisy and sluggish. It would also have trouble starting on a cold morning, splutter and carry on like a bitch. Switched to Penrite Synthetic 5W60 and it runs like a dream. Quiet, revs better, starts instantly.
Amazing how much a different oil effects the way a car runs. No harm in trying a different oil for a short period to see what works for you.
Edited by llama_au
how much oil would you go through in the sr out of curiosity?
why u ask?
Thought it was you but wasn't sure :D
Yeah talk to the dealers but don't get sucked in on the day. Some of the car dealers are pretty full on...
Tony, you an accountant? need some tax/claiming shit advice
Not just any Accountant, the best. Your welcome to come into my boardroom office, and we can sit around drinking bourbon liek a baws.
With Turbolight - if I ever left as long as 5,000km and didn't top it up between changes (think I only did that once) I lost nearly 2L. Considering that's more than half the SR's capacity that's terrible. And it never noticeably burnt it so yeah...needless to say I started checking the oil more and eventually decided the oil just didn't suit my car. My ex's SR S15 was exactly the same, though his seemed to disappear even quicker.
With Penrite you'd nearly drain as much as you put in.
As I mentioned my RB lost Turbolight as well (although not quite as much), but again, not suited to that engine. Tappets were very noisy running Turbolight.
Too many bad experiences with Turbolight in my corner.
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
