With Turbolight - if I ever left as long as 5,000km and didn't top it up between changes (think I only did that once) I lost nearly 2L. Considering that's more than half the SR's capacity that's terrible. And it never noticeably burnt it so yeah...needless to say I started checking the oil more and eventually decided the oil just didn't suit my car. My ex's SR S15 was exactly the same, though his seemed to disappear even quicker.
With Penrite you'd nearly drain as much as you put in.
As I mentioned my RB lost Turbolight as well (although not quite as much), but again, not suited to that engine. Tappets were very noisy running Turbolight.
Too many bad experiences with Turbolight in my corner.
hmm maybe i should stop using turbolite. no wonder im losing oil i thought something was eff'd in the car.. i had a look at everything over sunday and nothing was wrong but i was loosing oil..
might move along to a 15w50 especially for the summer.
Lol barbs I'm not that Lebo :P
Johno, no it doesn't lol!
If I don't get rid of it soonish I'll splurge in some camber arms, bushes etc. mate rekons it's a rear wheel bearing causing the arse to play around.
Wheel bearings make a humming noise on acceleration/deceleration (think a plane taking off) when they go, and you'd be able to move the wheel side-to side with a shake and hear the noise when you spin it with the wheel off the ground. I have had many a wheel bearing replaced (5 on the Pulsar and 1 on the R34.)
That's the funny thing, so many people find it disappears on their SR but people keep buying it 'cause it's got 'turbo' in the name, and turbo must mean it's better.
Try the Penrite Semi Synthetic 15W60 I recommended and report back on how the car runs and how the oil situation is going. It improved not just my SR but others I know considerably. Ignore it's blurb on the website but this is the one I'm referring to: http://www.penriteoil.com.au/products/motor-oil/hpr/hpr_15 - it doesn't really sell itself with 'older engines/pre-97 family cars' but it's not very expensive so it's not going to hurt to try. I ran it on the track and on the street. It'll give your SR plenty of protection going into a hot summer. They've got nice full synthetics too but they're not really that necessary unless you're making massive power or it's a newer engine.
you replace just the bearing or whole hub? i need to do my rear left
Whole rear drivers side hub, Nissan had one in stock in the country at the time. It wasn't cheap, at all.
Stupid ripple strip, it ruined my sideways.
Try the Penrite Semi Synthetic 15W60 I recommended and report back on how the car runs and how the oil situation is going. It improved not just my SR but others I know considerably. Ignore it's blurb on the website but this is the one I'm referring to: http://www.penriteoi...-oil/hpr/hpr_15 - it doesn't really sell itself with 'older engines/pre-97 family cars' but it's not very expensive so it's not going to hurt to try. I ran it on the track and on the street. It'll give your SR plenty of protection going into a hot summer. They've got nice full synthetics too but they're not really that necessary unless you're making massive power or it's a newer engine.
i just bought it because it was 1 down from 300v.
the SR I have has only done about 30-40,000km.. its a built motor.. and i did notice after doing the first service with turbolite the forgie rattle was a tad louder.. no harm in trying.. ill see how it goes or might just go the 100% synth if the price gap isnt too large.. ill report back. was doing the second service on it coming weekend.
plus mine takes about 5 and a bit litres with the ARC sump extension and oil cooler..
lol aint it all the same? just a different company supplying the credz?
Sort of the same. Depends on where you work. But CA is alot harder than CPA.
Had alot of people at our firm come from CPA backgrounds, try the CA and then fail hard. Failure rate in CA is pretty high. And when someone fails at work they usually cry, because you've just wasted money and 1/2 a year studying your arse off outside a full time job for nothing...
can get bearing from just jap for like $160 compared to 250 from nissan probably just go that way
I was in a bit of a hurry to get my car back so I didn't search but Nissan were damn expensive I agree.
Did you cry? It's ok brah you can tell us
Oh that's pretty young, it shouldn't be losing oil like that! Maybe a full synth seeing as it's still a young engine? If it's in your budget that is: http://www.penriteoil.com.au/products/motor-oil/sin/sin_engine_oil_10
Oh that's pretty young, it shouldn't be losing oil like that! Maybe a full synth seeing as it's still a young engine? If it's in your budget that is: http://www.penriteoi...n_engine_oil_10
nah i put 5 litres in, and about 3.5-4 litres come out.. i know im losing a tad through the turbo as well. we'll see how it goes.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
