With Turbolight - if I ever left as long as 5,000km and didn't top it up between changes (think I only did that once) I lost nearly 2L. Considering that's more than half the SR's capacity that's terrible. And it never noticeably burnt it so yeah...needless to say I started checking the oil more and eventually decided the oil just didn't suit my car. My ex's SR S15 was exactly the same, though his seemed to disappear even quicker.
With Penrite you'd nearly drain as much as you put in.
As I mentioned my RB lost Turbolight as well (although not quite as much), but again, not suited to that engine. Tappets were very noisy running Turbolight.
Too many bad experiences with Turbolight in my corner.
hmm maybe i should stop using turbolite. no wonder im losing oil i thought something was eff'd in the car.. i had a look at everything over sunday and nothing was wrong but i was loosing oil..
might move along to a 15w50 especially for the summer.
Lol barbs I'm not that Lebo :P
Johno, no it doesn't lol!
If I don't get rid of it soonish I'll splurge in some camber arms, bushes etc. mate rekons it's a rear wheel bearing causing the arse to play around.
Wheel bearings make a humming noise on acceleration/deceleration (think a plane taking off) when they go, and you'd be able to move the wheel side-to side with a shake and hear the noise when you spin it with the wheel off the ground. I have had many a wheel bearing replaced (5 on the Pulsar and 1 on the R34.)
That's the funny thing, so many people find it disappears on their SR but people keep buying it 'cause it's got 'turbo' in the name, and turbo must mean it's better.
Try the Penrite Semi Synthetic 15W60 I recommended and report back on how the car runs and how the oil situation is going. It improved not just my SR but others I know considerably. Ignore it's blurb on the website but this is the one I'm referring to: http://www.penriteoil.com.au/products/motor-oil/hpr/hpr_15 - it doesn't really sell itself with 'older engines/pre-97 family cars' but it's not very expensive so it's not going to hurt to try. I ran it on the track and on the street. It'll give your SR plenty of protection going into a hot summer. They've got nice full synthetics too but they're not really that necessary unless you're making massive power or it's a newer engine.
you replace just the bearing or whole hub? i need to do my rear left
Whole rear drivers side hub, Nissan had one in stock in the country at the time. It wasn't cheap, at all.
Stupid ripple strip, it ruined my sideways.
Try the Penrite Semi Synthetic 15W60 I recommended and report back on how the car runs and how the oil situation is going. It improved not just my SR but others I know considerably. Ignore it's blurb on the website but this is the one I'm referring to: http://www.penriteoi...-oil/hpr/hpr_15 - it doesn't really sell itself with 'older engines/pre-97 family cars' but it's not very expensive so it's not going to hurt to try. I ran it on the track and on the street. It'll give your SR plenty of protection going into a hot summer. They've got nice full synthetics too but they're not really that necessary unless you're making massive power or it's a newer engine.
i just bought it because it was 1 down from 300v.
the SR I have has only done about 30-40,000km.. its a built motor.. and i did notice after doing the first service with turbolite the forgie rattle was a tad louder.. no harm in trying.. ill see how it goes or might just go the 100% synth if the price gap isnt too large.. ill report back. was doing the second service on it coming weekend.
plus mine takes about 5 and a bit litres with the ARC sump extension and oil cooler..
lol aint it all the same? just a different company supplying the credz?
Sort of the same. Depends on where you work. But CA is alot harder than CPA.
Had alot of people at our firm come from CPA backgrounds, try the CA and then fail hard. Failure rate in CA is pretty high. And when someone fails at work they usually cry, because you've just wasted money and 1/2 a year studying your arse off outside a full time job for nothing...
can get bearing from just jap for like $160 compared to 250 from nissan probably just go that way
I was in a bit of a hurry to get my car back so I didn't search but Nissan were damn expensive I agree.
Did you cry? It's ok brah you can tell us
Oh that's pretty young, it shouldn't be losing oil like that! Maybe a full synth seeing as it's still a young engine? If it's in your budget that is: http://www.penriteoil.com.au/products/motor-oil/sin/sin_engine_oil_10
Oh that's pretty young, it shouldn't be losing oil like that! Maybe a full synth seeing as it's still a young engine? If it's in your budget that is: http://www.penriteoi...n_engine_oil_10
nah i put 5 litres in, and about 3.5-4 litres come out.. i know im losing a tad through the turbo as well. we'll see how it goes.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
