Sure will look like a baws driving that
My father has one and, of all the vehicles I've been in nothing compares for the fun/excitement factor. I will own one, one day, just need to wait for the right one and some good timing.
Its called being wise.
I can't see the logic behind spending enourmous amount of money on your girlfriend unless its your wife, then you're sharing incomes together.
If you want to go out and joy some time together, get her to pay for the bill every now and then. If you're having to pay over 60-75% of the time, shes using you and most likely screwing some one else behind your back.
you got no fkn clue man, hence why your single. my missuz is at uni doesnt work much im on 6 figure income why the heck would i worry about who pays for what?
its evident yuor single, and will be for the forseeable future.
thats the stupidest thing ive ever heard.
chivalry never met you didnt it.. you being a tight ass explains the no gf thing lol
this.
Not really brah.
In a modern day society where women have occupied almost half of the work force, especially the service sector, men don't really need to dish out for women anymore. If she has a stable, secure income, you shouldn't be paying for anything for her. She's more than capable enough to pay for her own shit.
Not to brag or anything but.. i have met and fondled with girls that had a boyfriend treating her like a princess.
sure you did man, sure you did. Chances are she was a pig and her own bf didnt wana touch her so you got the scraps
this.
You have no personality
this.
Did i hit a nerve there sweetie pie? :kiss:
Some of us don't like to be tied down by a girlfriend... this aint no scooby doo Alex, we don't fall in love with anyone who comes our way willing to hold our hands :wub:
:laugh:
My mrs offers to pay for pretty much everything pretty much all of the time, and she doesn't do it as an empty gesture. I still pay for most stuff (dinners/movies etc) but usually have to force her to let me pay...She's a keeper :)
yeah my new ones like that, but i still try to pay as much as i can
but its better than the gold digger that i last had lol
No rain here in the north east... suffer
no rain here..... in the sticks :P
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
