Good thing about commercial/industrial is they get you doing actual work straight away where as in domestic unless you're working for a relative or friend you're basically a labourer for the first year or so doing just the crap stuff like digging, cleaning up, getting tools etc.
You start tafe next year yeah? Hope you like using the reg book lol
Always heard the opposite, that you get lost in big companies and end up being a cleaner/labourer for the first year, whereas in domestic you get thrown straight into wiring up houses coz it's just u and the boss or 1 a grader etc. But yeah so far it's been good, the other guy that started with me has been cutting/filing cable tray so I'm sure I'll cop that soon enough. Gotta be done.
And I read AS 3000 before bed
yeah maybe if its just you and the boss he'd have no choice if he has no other more experienced apprentices but most of em dont wanna waste time teaching while working just want you there as an extra pair of hands
Cute
Holy f**k Twin Turbo 300ZX's are cheap!!!
Having to pull out all the drivers side intakes and shit to get to the PS lines/pump 5 or so times did my head in but now for some reason I want one, Stockholm Syndrome?
Never filed cable tray before, makes sense though I guess haha
I'm a 2nd year at a domestic/industrial/commercial company. Mainly doing bunnings stores at the moment.
Small company = learn more
Big company = earn more
Depends what's most important to you IMO, I get the bare minimum award wage, but I learn a hell of a lot more than people I go trade school with who earn a fair bit more than me, but it's an apprenticeship so I'd rather gain as much knowledge as possible and then earn more than them in the long run haha
Summer is just around the corner. Shoulda started a lil while ago lol
I'll take a tray load. no homo.
Yeh I did start about a month or so ago, don't get me wrong I'm definately seeing results just want that little bit more, I guess I gotta work that little bit harder and eat that little bit better / more. Guess there is no tricks for speed other than that or roids as Alex said :P but then you get shrinkage amirite?
and after replacing all the balljoints and bushes on one, it ain't gonna be cheap anymore.
Dunno still as large as ever ere
Agree and disagree...
Not just a case of 'what's most important', for some it's a matter of what they can/can't afford to do. I'm 25, almost 26, and have a mortgage...So domestic/small company/non EBA is out of the question for me. Sure you might learn more to begin with, and probably wire neater, but it evens out in the long run (got mates in domestic, mid size companies and the big boys) after around the 2/3 year mark everyone is pretty much on a level playing field...At the end of the day you'll learn as much as you want to learn. I know I've only been there 2 days, but I can tell the guys I'm working with are happy to teach me as much as I want to learn, and aren't just using me as a labourer.
As for the pay side of it, a 3rd year apprentice on an EBA job makes more than a domestic A grade, so unless you own the business or you're doing work on the side, there's no comparison in the pays.
My mate is 3rd year and on $40 an hour....
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
