alex you just need this part with no other code or tags around it,
http://www.youtube.com/watch?v=2muQaGex-pw
just make sure you got watch?v=2muQaGex-pw and cut off any other crap off the url, generally added when browsing through related videos etc.
http://www.youtube.c...h?v=2muQaGex-pw
lol.. indian michelin man
david guetta special on GO...pretty cool... :D
alex u just copy and paste the link man ( browser addres whatever u call it)...if it say something liek "feature related" at the end delete that bit..birds tawt me that :thumbsup:
Shit...haven't replied to your PM lol, will do that tomorrow.
Who's a GTR expert here?
Trying to help a friend replace his leaking stock R32 GTR injectors.
Can anyone confirm if the below information is correct? He has no after market ECU at the moment so fitting a bigger injector would probably mean his car won't run so his looking for a stock replacement atm.
Where my dogs at?
Black people had some groove, style and most importantly education back in the 60's & 70's mayne.. singing and rhyming to tunes of jazz and soul music... now however, lets not go there.
I walked into a wallmart in Culver City to find an adapter for my charger and boy was i for a surprise. The most arrogant, ignorant and most importantly poor (wealth wise) people I've met in my life. I was the only white person in the entire complex that was swarming with all black folks in all three levels.
US is phucked and i don't see it ever recovering from the decades of degeneration.
Be thankful your folks were granted a citizenship to this country and not to US, although Canada's pretty good too from i hear, so show your gratitude once in a while you maggot. Otherwise your folks would have migrated from one ghetto to another cause end of the day, parts of US is just that, an urban ghetto.
Tony, how many problems does Justin have with his GTR ATM?
Injector leaking... Had he tested the body itself? If so, what are the results. If body is fine, grab new seals.
Factory are 440cc low impedance and this seller is selling high impedance so won't work at all unless the ecu is some fancy aftermarket unit (motec, haltech, etc).
Cheers Grant, well it is a 1989 model so is in need of some TLC
Strange seller is trying to sell something that doesn't work because its a reply from a company workshop rather than a private seller.
i wouldnt call that racist though he's just stating an observation. a completely useless and irrelevant observation nonetheless
How is his stereotypical view of black people not racist?
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
