Good shit, I stopped playing ages ago but used to play Quake 2 and 3 back in the day. Was pretty good at it represented in comps/clans and was in a Aus V NZ battle.
Entrepreneurial skills right there, all disclosed in your Tax Return of course :ninja:
I was all about counterstrike. Haha. Almost made to top of WCG Aus.
@taxreturn, umm... yeah of course! :nyaanyaa::ph34r:
Edited by PENGUYEN
Hahaha, nah I used to have some funny scripts that trashed servers etc.
I used to be able to crash servers just by joining and overloading with requests, but I digress, those days are long gone.
scoutzknivezrepresent
is this not relevant?
Haha well played sir, the mo must be giving you extra wisdom (no, not you Mohsen)
Getting paid $25 a day just to drive to work, and $4 an hour just for working on this site.
Projected gross income looking pretty good for a first year apprentice :)
Might be time for another Skyline then ey Dezzy
Cause zombies is spraying everywhere, and the source engine, hit boxes are all over the place. Not to mention the recoil is stupidly easy to control.
HL1 ENGINE REP!
Edited by PENGUYEN
I agree about controlling the recoil easily, used to spray an entire AK47 clip and kill a room full of people with it, with most hits being headshots lol. You can't pull that shit in COD. Should have a CS night.
Main reason why 1.6 > source. Requires more skills :D:P
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
