He's been my next door neighbour for the last 25 years and hasn't realised it until now.
I live next door to @Dan_J and for the last year we've both had black cefiro's in our driveway that don't run properly, so haven't moved. We haven't spoken in person yet, just over forums.
I think I'll still driving in Skylines whether it's same or different.
Having 7 of them and I think I can't stay away from them...
maybe if you kept one for a while and dont decide to sell it your numbers may be less....are you thinking to sell the one you have got now just so you can buy another one AGAIN
Half of me use this as an excuse. But I think I'll have the purple one for a while... Unless I'm forced to buy something suitable (depending on whether I have the money or not).
Buy a 35R grant.
Wanna go halves?
Would be curious to see what GTR prices will be in say 2 years time
At the moment approximately
R32 GTR - ~15K
R33 GTR - ~18 - 22k
R34 GTR - ~40 - 50k
09 R35 GTR - ~110 - 120K
Say in 2 years approximately
R32 GTR - ~6-8K
R33 GTR - ~10 - 15k
R34 GTR - ~30k
09 R35 GTR - ~80K
Also would be curious of how the performance cars will be in 2 years. Will we have 300kw Evo's, 400kw HSV/Fords. Or will they all be penalised by the environment/safety feature or be hybrid's and weight an extra 200kg's.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
