According to the Age:
http://theage.drive.com.au/motor-news/first-drive-toyota-86-20111128-1o1vi.html
'Less than $40,000'
But at 140kw, I don't know man. Maybe a car for the missus
hmmm, power-to-weight ratio is same as a stock r32 gtst.
Im keeping my eye on it as it will probably handle and feel like my r32 but with everything being new and not rattling/falling apart haha
If someone comes up with a turbo kit for it, it should be pretty good. However, I would have prefered to have a reliable Toyota engine...
Give it 6 months from new, there will be a kit commercially available. Will seriously consider upon test drive...but I did see a late model Celica today and it reminded me of the 86 quite a bit :(
I knew Toyota would have to make something bland about it...why did it have to be the engine :(
Plan for Jan 2013? :P
it just needs some phat wheels and stance to be epic imo.
with a turbo would be so awesome really hope they bring one out down the track a trd version or soemthing.
for sub 40k it has no competitors i mean a 370z is 70k new!
Gardening is a pain in the arse.
Redoing my small backyard, massive front yard and side yard.
Progress of the back so far. Before and after
Front is a blank canvas at the moment
sheesh, that looks like a huge property? Demolish and build units?
UK ain't all it's cracked up to be. Their petrol is ridiculously expensive and enjoy your rego on anything with more than a 2 litre engine...then there's the ugly, fat and depressing lifestyle/weather.
Import from the states = $30k to do a proper conversion from LHD.
It's not as easy as it sounds; for every loophole you can think of around paying high prices for cars locally, it's all been thought of / done before. This is reflected in the prices of our local second hand market and the overseas import markets. It's the reason why you can go to Japan and buy a 1998 RX7 for $9k, whilst a 1999 RX7 will cost you $18k - the latter can be imported to Oz.
Buy a delivery km Mustang in Australia for ~70k-80k, the same car will cost you 35-40k in the US...add your RHD conversion, shipping etc. You might come out 5k better off after the hassle and risk involved in importing yourself.
Personal import is probably the only thing worth considering to save money, if you can pull it off...
Die in a fire!
mmm love the old school americans
old man owns 2 68 RS camaros (one driving and other one about to be restored) and a 57 chev belair (being restored atm)
And that Yenko will snap a speedo in about 5 seconds flat
also cost you $300k plus :P
I could design the front if you want >:| I has the programs to do so. Hehe.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
