According to the Age:
http://theage.drive.com.au/motor-news/first-drive-toyota-86-20111128-1o1vi.html
'Less than $40,000'
But at 140kw, I don't know man. Maybe a car for the missus
hmmm, power-to-weight ratio is same as a stock r32 gtst.
Im keeping my eye on it as it will probably handle and feel like my r32 but with everything being new and not rattling/falling apart haha
If someone comes up with a turbo kit for it, it should be pretty good. However, I would have prefered to have a reliable Toyota engine...
Give it 6 months from new, there will be a kit commercially available. Will seriously consider upon test drive...but I did see a late model Celica today and it reminded me of the 86 quite a bit :(
I knew Toyota would have to make something bland about it...why did it have to be the engine :(
Plan for Jan 2013? :P
it just needs some phat wheels and stance to be epic imo.
with a turbo would be so awesome really hope they bring one out down the track a trd version or soemthing.
for sub 40k it has no competitors i mean a 370z is 70k new!
Gardening is a pain in the arse.
Redoing my small backyard, massive front yard and side yard.
Progress of the back so far. Before and after
Front is a blank canvas at the moment
sheesh, that looks like a huge property? Demolish and build units?
UK ain't all it's cracked up to be. Their petrol is ridiculously expensive and enjoy your rego on anything with more than a 2 litre engine...then there's the ugly, fat and depressing lifestyle/weather.
Import from the states = $30k to do a proper conversion from LHD.
It's not as easy as it sounds; for every loophole you can think of around paying high prices for cars locally, it's all been thought of / done before. This is reflected in the prices of our local second hand market and the overseas import markets. It's the reason why you can go to Japan and buy a 1998 RX7 for $9k, whilst a 1999 RX7 will cost you $18k - the latter can be imported to Oz.
Buy a delivery km Mustang in Australia for ~70k-80k, the same car will cost you 35-40k in the US...add your RHD conversion, shipping etc. You might come out 5k better off after the hassle and risk involved in importing yourself.
Personal import is probably the only thing worth considering to save money, if you can pull it off...
Die in a fire!
mmm love the old school americans
old man owns 2 68 RS camaros (one driving and other one about to be restored) and a 57 chev belair (being restored atm)
And that Yenko will snap a speedo in about 5 seconds flat
also cost you $300k plus :P
I could design the front if you want >:| I has the programs to do so. Hehe.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
