I've done this UNINTENTIONALLY few times to other cars, when carrying items out of my car in some tight parking spots.
It happens mayne, but to key their car for it..
gotta agree with you, pains me to do it but it does seem extreme rimon
pls dont bash me rimon <3 haha!
alex agreeing with Flynn? what is this world coming too?
FML - smasged my iphone.. who invented concrete.. bastards
Couldn't care less about the chip it's more about teaching idiots a lesson. I don't think it's an accident when you could've easily used your brain and considered the cars around you.
I fear for your future children.
So many things wrong with this. I'm not even going to begin to attempt explaining what you clearly don't and won't see.
Kadz, I'd want a charged 8 mang.
I kid you not. I have dropped my iPhone from standing height, on concrete like 5 times and not a scratch lol
I don't want to park next to rimon. Unless I need help taking my doors off.
Do you think if they intentionally didn't own up to it they would have left their car next to yours when they had the opportunity to get away so easily by just parking somewhere else? More likely they didn't even realise they had done it and would have been extremely remorseful if they did.
I've been hit by cars on my motorcycles all of three times because they were not as observant as they could have been, including one attempting to hit and run. I think this is a little higher on the scale than your experience but none the less, I did not react the way you did and I never will no matter how huge the mistake.
Keying someones car isn't going to teach anyone anything, you just wasted your time. I think you know this and did it purely as pay back. You don't actually care about teaching them a lesson (it's obvious this approach is not effective). As if you care about the next person that car parks next to and accidentally knocks. You were vindictive to make yourself feel better.
It's amusing to see you are actually proud of being this way. Something thankfully only you are forced to deal with - enjoy.
Who gives a fark about what rimon did. Right or wrong, it's his choice and none of our business. I personally wouldn't have done it, but I know plenty of people who wouldn't have left a straight panel on that car...
The moral of today's lesson is that, when somebody pisses you off, you call rimon.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
