Hear and see a old Commo wagon tearing it up past my house, tyre screeching and all and I think wtf.
5 secs later an undercover cover rips past giving chase.
Fcking A lol.
Commodore driver ain't stopping either.
Sounds very exciting over your place.
Had the perfect view as well. House being a corner block seeing them drifto around the corner.
I cant hear no heli.
You in Springvale atm? They were heading in that direction. Car decided to turn down the small streets instead of exiting at Springvale Road.
You enjoyed the action?
Made my night.
Commo driver needed new tyres though. Was still wheelspinning 15m from corner exit. Just sayin.
Im near bunnings atm. hahahaha.
lol at nick.
You spend so much time over the South-east you may as well move over this end. Do da right fing.
interesting leigh!
the car was running 118's @ full weight, anyone know enough about boring/pointless/homo drag racing to derive a rwkw figure from that?
FWIW i ran consistent 119's with 325rwkw @ 1350kg
Different power delivery would mean different MPH, F6s same weight and run much higher MPH for a similar time. There's a lot of discussion about the low MPH on the ford forums. Still sounds like the only way to prove actual rwkw would be a SAU dyno day lol care for a wager? :P
Made my night.
Doubt he/she'll have the coin to purchase new tyres once the po-po got a hold of him/her.
RWD - 509bhp & 1850kg
Power to Weight:280 bhp/ton
0-60:4.5
0-100:9.5
60-100:5.0
1/4 Mile ET:12.36
1/4 Mile Terminal:118
Dragstrip 1/4 Mile ET:12.16
Dragstrip 1/4 Mile Terminal:122
Calculation for the FPV GT on that vid is @ the 380rkw mark
RWD - 435bhp & 1350kg
Power to Weight:327 bhp/ton
0-60:4.1
0-100:8.6
60-100:4.5
1/4 Mile ET:12.08
Dragstrip 1/4 Mile ET:11.88
Hamish ur car stats, Give or take up to .3-.4 on the quarter @ those speeds for certain tracks dependant on how much above sea level.
these calculations are not gospel but approx
This also doesn't take into consideration diff gears, torque etc obviously.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
