Leigh should've gone white
Thats a modded f6.. vs my bog stock lol and yeh looks good in white i know :) but i prefer the GS in black
See doesnt look as good, eventually ill get a GT / F6 rear bar keep the rest of the body standard, lower it - better rims etc.
E.G:
stock rear bar still not bad:
but i like the GT rear bumper:
Give me some time and will be a boss of a car, no pun intended.
i thought that's what F6s looked factory no?
what's the difference between yours and the GTP? also which one is higher in the range GS GT or GTP?
Yeah it is, but the f6 and GT look different to the GS (better) is what im getting at, and when i say modded just lowering it and putting a decent set of rims and stripes make it looks soo much better.
In new engine order goes:
GTP is best "335kw", 6/4 brembos, better seats, different wheels etc (f6 / GT bodykit)~85-90k
GT is below "335kw", 4 pot brembos front, not as good seats no brembos rear (f6 / GT bodykit)80k
GS is below "315kw" bit more detuned stock, same driveline minus the 4pot bremb, bodykit and slightly different seats ~60k
F6 start at 60k without options, but I wanted the 8. IMHO felt a lot like a taxi when you wern't floggin it.
Basically couldn't justify (or really wanted to spend) the extra for what you get, guess its a bit like if a GTST had a rb26, 4wd and no brembos lol
Hope that made sense, thats all the FPVs in a nutshell.. minus the GTE and F6E which are luxury exec versions.
ah i see
yeah big price difference. aslong as you know you wont regret anything when you pull alongside 1 of the higher spec models :/
Yeah they are nice but the difference is quite a bit, I'll be making my car my own and enjoy the hell out of it :D
Anyone on here using plazmaman products? Had a mate running a fmic on his xr6t and couldn't speak any higher of it. Definetly thinking of saving for a few months and getting a fmic with their plenum.
One user here went backwards upgrading plenum...
And realistically, unless you are over 350rwkw, there is no need for it - or the defect
About 1800, maybe a bit less which is expected I guess for a big car.. got about 300kgs on my old GTR :O.. still do a tune and your in 11s.
You think a R33 GTR weighs 1500kg? :spank:
It's more than that. Especially once you add exhausts, wheels/bigger tyres.
Gotta get mine onto a weight bridge shortly and I'm not expecting to see it under 1600kg, with me standing outside.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
