Fpv motor is lightyears ahead I thing hsv interior is much nicer and more advanced equip with edi an stuff horses for courses both great cars just need my skyline to hurry up an sell! Haha
Then buy this and we can go invade SAU cruises
http://www.carsales.com.au/bncis/details/hsv-gts-2011-11772886?cr=31&distance=25&vertical=Car&eapi=2&Page=3&sort=Price&__N=1216%201246%201247%201252%201282%204294965530%204294965529%20903&silo=Stock&Range=Price:60000,Max~1
Jeppe it's not a realistic comparison to put hsv/fpv to BMW/merc etc as your talking m5/e63 comparison for size but 170k MORE in price hardly comparable
I also included Japanese and was only speaking from an asthetical point of view, it wouldn't need to be top of the line Euro.
Also I don't think just because a car costs less it has an excuse to be less attractive. They're targeting a different market, I'm obviously not that market.
holy shit just came back from a massive car meet at knox shopping centre (at the back). I think it was eastide cruisers? So many old school american muscle cars. They had to turn back plenty of cars because there wasnt enough space.
Cant find any info on the net about it?
Now thats a show and shine!
Havnt you been to those before? every 2nd tuesday of each month been going for a while now (i think every summer more so)
and yes they are awesome I was there today with my bike :)
You do if your comparin from a performance perspective and sub 100k will barely get more than a 2.5ltr or a diesel nothing 8cylinder/ High performance
nah never been. Was driving back home from work and was surrounded by all these muscle cars including ford GT's, trans-am's etc. Was wondering what the hell is going on. Decided to follow haha
So many nice cars with vic rego's. So bloody loud too.
someone showed up with this;
didnt even know we had cars in victoria like that haha
and a 605cubic inch (10ltr!) v8 camaro haha
was there a kingswood there with the plates SLOWGM?
guy i went to panelbeating tafe owns it
that thing is sick, rare to iirc
plymouth roadrunner is a fkn beast. ~300kw ran the 1/4 in mid 13s. not bad for a car from 1968
You're correct :) asthetics and performance are completely different ball games :)
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
