what does everyone think of USDM styled cars
shit... like everything the yanks take it too far in some pathetic attempt to beat everyone else in something that is not a competition
What is usdm exactly? Looks like jap cars with euro/jap wheels on them..
Would usdm refer to us made vehicles?
technically yes, but as far as styling goes, usdm is essentially fatlace inc
Yeah I know you know what it means, but even JDM doesn't mean anything, people use it as if it means Japanese development motorsport to make themselves feel special about owning an import, but it's like calling a silvertop taxi ADM....
yeah, it does... it mean's Japanese Domestic Market.... just as USDM is United States Domestic Market
the term actually refers to the original country the car was delivered to :)
So my girlfriend was at my place...Walk her out when she was heading home, wearing nothing but a pair of shorts. Once outside I noticed how chilly it was where as inside was still quite warm, hence the lack of clothing...
Closed the door behind me so no flies/insects would get in...Wave to her as she drives down the street, still cold but it's rude to go inside before the person leaves...
Turn around to open the door, locked. Phone inside, keys inside, clothes/shoes inside...
Quickly run down the street in the dark, barefoot (quite painful) trying to catch her, but unfortunately for me she isn't a slow driver.. Then had to run to my brothers house, still barefoot and shirtless obviously. Thank f**k he was home or it would've been an hour or so walk to my parents house, again, barefoot and shirtless...
Eventful end to my birthday..
Edited by Flynnn
Thanks, I know all that and wrote it above. Point was that shit like 'JDM as f**k' means f**k all.
People use JDM as if to refer to the way the car is styled (good offset/stance etc), but the 2 have nothing to do with each other \
This is 'JDM as f**k'
ADM as f**k
USDM as f**k
There is something about yourself that you don't know. Something that you will deny even exists, until it's too late to do anything about it. It's the only reason you get up in the morning. The only reason you suffer the shitty boss, the blood, the sweat and the tears. This is because you want people to know how good, attractive, generous, funny, wild and clever you really are. Fear or revere me, but please, think I'm special. We share an addiction. We're approval junkies. We're all in it for the slap on the back and the gold watch. The hip-hip-hoo-f**kin' rah. Look at the clever boy with the badge, polishing his trophy. Shine on you crazy diamond, because we're just monkeys wrapped in suits, begging for the approval of others.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
