I Sold my 1998 r33 GTR for 19.5 i think it was
had a few mods too.. and it took a while to sell so just keep looking.
It had a little bit of surface rust at some spots though
ahh how long ago was that man?!
i havent been around for a while :(
I would of prob checked it out!
im looking to buy one asap due to ill be using it as a daily for a few months >_<
My only thing with the R35 is that would you have fun driving a R35 compared to say a GTR if it's for the street only. For the track the R35 will be no doubt quicker out of the box.
You could say the R35 is too quick for the street.
But hey at the rate that the R34 GTR is holding its price and R35 is dropping in value in a few years R35 might be hard to say no to
was in october last year
not really to me
Was next to one at the lights on Sydney Rd. and I'm pretty sure it sounded just like my 33 with the exhaust on whilst it was idling.. taking off however had a lighter tone to it. Changed three gears by the time mine shifted to second despite the driver just cruising it
Exactly.
Just the troll, trollin'
What exactly is trolling with that post?
Expressing ones opinion on a small experience is now considered trollin?
You seriously need to cut this holier-than-thou moral smugness attitude of yours and urgently get your self in check.
It's uncalled for.
Edited by Flynnn
My requirements for this bike are:
1. Cannot being converted into a track bike, aka not full faired
2. Pops many wheelies, hence 1098 cc and S edition :3
The only Harley I would ever ride/buy is this one:
'Hey! Fatboy!' (In Lucy Liu Payback voice)
Unfortunately I think mono's could only be done with great difficulty, and it does kind of cost $65k >_<
Just booked in a test ride on this for Friday:
A little bit excited, they have a demo for sale in my size and colour :thumbsup: I hope it rides like I want it to!
Ohhh look at that, matching colours...we should go for a ride if you get one :whistling:
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
