Why can't girls just get along?
6 years at working at the same place and there has always been a tensions/girls not get along/bitching between different sets of girls.
This also applies to girls that I'm friends with too.
All the work guys always get along and also the group of guys outside of work have never had a qualm.
Feel like I'm Dr Phil when girls are breaking down in my office.
Just sit their and listen but you can't touch! A manager has been sued before for trying to comfort a crying employee :/
thats seriously dumb!
human nature is to comfort someone when they are crying..
getting sued for it is pathetic!
Show him your roof :P
carbon fibre shtickerrrr!
Mirror finish :P
:thumbsup:
Hmmm well I have the a1rm sitting there atm so I might get them put in for the time being. Look into red stuff when I get a chance.
not a valid reason to chew through the DBA's.
QFM HPX's are like $80 a pair
Yup a manager got taken to court for comforting a staff member after she was crying. I.e. rubs on the back and a hug.
Case was dismissed in court, but having that mark against your name and months of stress wasn't good for the manager.
So I just sit back and hand them tissues :D
And yes bitches b crazy
And that there is one of the reasons people aren't as nice to each other anymore...you can get sued for being nice and errr...crims with bad intentions get off pretty easily :/
I remember some guy saying how he can't even look at or say hi to people's kids at the supermarket anymore, for fear of being thought of as a creep/pedophile...can relate to this. The times, they are a changin'.
That said, can't wait to get stuck into the ladies at my new job lol
Sexual harassment at a...legal firm? You got balls :P
i have my gtst going in for a rwc tomorrow morning - he keeps telling me my return flow fmic will need to come off..
just wondering if anyone knows where can i find documentation which shows its legal?
I've only been able to find it on the EPA information bulletin
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
