I agree Dez
People who actually believe that shit.
I say go commit a crime, use that argument.
Let me know when the court date is so I can come for the lulz
lol would be f**kin awesome to watch some cunt get locked up for some bad shit coz he thought he could pull this..
That Josh guy is a classic...even IF this bullshit was true, I guarantee the cop wouldn't have a f**king clue about it and there is no way in hell he'd drive away from being pulled over at 160km/h
Bunch of shit fallers and despos on there some ugly chick posts up some random shot 1000 comments later they still trying to get there end off.. Few of us took the piss out of the loser the other night for trololols
tell him to show you where it says that a return flow front mount is illegal (as long as you don't have a pod)
failing that, call him a cocksucker
One intake modification is allowed, you can have Reverse-flow FMIC assuming you still have standard airbox.
Failing that, do what Dezz said.
yeah i have only the blitz return flow/reverse flow fmic.. and i chose that one due to it being legal.
i am running standard airbox also..
coilovers i have tein monoflex and cant put standard ones back in because the rears were both gone within the first few months after buying the car..
so i guess ill either be telling him he is a 'cocksucker' or ill talk my way through a rwc
Ahahgahahahahhahahahah
Ohhhhhh alexxxxx <3 no homo
It's true though, about the FB stuff at least. It seriously hurts my eyes, and brain. Least it keeps it off the forums, means less work for me.
Mmm will depend if im catching up with a lady or not.
However unlikely regardless I think... Mt Baw Baw sprint is on the w/e after. Really cannot afford to put that in jeapordy as it's going to be farken nuts!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
