Vic Wasteland Thread
R31Nismoid
Yep necrosis is nasty shit. Look up pics of brown recluse spider bites if you want nightmares...thankfully these are confined to the Americas. But white tail bites can end up pretty bad!
Wolf spiders are worse than the white tail's, just not as many around than what you will see white tails
although i nearly got bitten at work from one, one day last year... scary shit, there bites kinda are like the brown recluse spider
You've got 20/20 vision now?
Better than apparently, even just a day after I could easily read the bottom line of the chart. Whereas before I would struggle a fair bit and only make out what the letters are.
All 250 sound pretty shit, excluding two stroke or v-twin. Ninja has become the new CBR250, which was the beginner bike to have before they got old. Anything you get you will be happy with, just being on a bike as a newbor is thrilling.
Just got trips in 3 card poker at Crown, pays 33-1 :D
apparently late model 250 ninja is the way to go for beginner. but looks too thin and sounds queer so meh
You won't really find anything else LAMS approved that looks as good as the 250 Ninjas do...That's what I'll be getting
Unless you get a Hyosung, they look ok, not a fan of the headlight though
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
    • I wonder if there is much to tell without knowing where the bolts where bought from. If it comes from Amazon or similar all bets are off. Can't trust them. And I fear not everybody knows that. Wasn't it @TurboTapin who ended up with the fake fuel lines recently? The submersible ones which very much weren't submersible at all. It kind of applies to everything nowadays. Doesn't matter if it's hardware or electronics. The fancy camera might have internals swapped out for cheap knockoffs. The hard drive will report a certain size but not actually be able to write it all. Shit like that. A bit depressing but the reality is you really have to be weary of where and how you buy stuff
