3200GT (I know you don't like them though lol)
wouldn't say no to one lol
I rkn rimon a 30-40k one will be can of worms likely high kms no warranty and everything costs lots to fix it's not a good combo!
Scott seems to be happy with his purchase...
i think
Don't need a car for that
lulz if an ek civic with fake recaros and dodgy electrical tape race numbers on the windows attracted bitches(i dont know why.. was just a piss take)
think a maza would go sick. those things are growing on me now btw
You might not, he does
:laugh:
ill bite ya face kunt
BTW
mah niguhs. car is pretty much a bare rolling shell now so its a blank canvas.
considering other colours now.
wine red metallic?
So true some of the ugly colour combos can save you heaps, for some reason black on beige/white commands a premium probably cos it looks baller
There are some feral colours indeed.
I feel like hitting the guy who came up with 'platinum bronze' (essentially 80s champagne colour). Oh and Marakesh brown (a lot of the X1s and X3s come in that colour).
A lot of the dark blue(s) and grey(s) seem to be cheaper too when it comes to the 335s.
Black and white are always more expensive.
The best part about rebuilding a 20 year old car with 20 year old parts is that every new part will be as unreliable as the rest of the parts you didn't replace.
Mechanical parts will be new/reconditioned
Aesthetic, 20 years old.
lol ill wave at every 5 series then! bound to eventually see you!
also there is another guy who lives off king street who has multiple skylines, r32, r33 and a v35, was also another r33 and r34 parked on his lawn today, wondering if its someone here maybe?
or maybe you know or have seen them grant?
OH nah i know the guy you mean lol nah not him, thats another one though!
about halfway in between your place and that guy there is another guy but he is down the street near the dentists on the corner if you know where i mean :P
I think I know where that, never knew that.
I haven't really ventured off King St, except for one road that leads to Serpells St the one with School and retirement village.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
