Is it true you can shift without clutching and it does no harm?
This plumber was telling me he never clutches after take off...
Widely debated, but lots of people say that they shift clutchless and never have an issue. I would only do it on the upshift though...
Hmm the Megelli 250R looks even better than the Ninja... None for sale second hand in VIC though...$6k for a new one
The stand hits the ground on left hand leans. YouTube the review clip.. Wouldn't be much fun for a spirited ride and the happens..
like birds says, only upshift.. you have to revmatch to shift down. but it can be done too..
although i have no idea why someone would do that if they had a clutch..
i had no pressure in my clutch pedal for a period of time, had to do the clutchless shifting till i had it fixed.
Pretty sure he's talking about bikes, clutchless shifting is a little bit faster.
I got a sore left hand at the moment, and I sometimes forget to use the clutch cause of the pain and it changes gear.. down gearing is a little clunky haha
What are you riding around TJ? Still hitting the gym?
WTF?!
Hey TJ, where you been man!
what up Jamie!
been working messed up hours bad! living other side of the city now, no more SE for me haha
im on a Kawasaki GPX250 ( old ninja, few pages back ) gym ? hehe not for a long time, gone all soft like now hehe
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
