I have no idea about it. I have a meth kit, as it came as part of a tuning kit for my car. The ECU in my car does have a 'meth' map.
I might have the same kit or similar. But mine says something about mixing water and meth in the window washer bottle.
Too much confusion.
Anyone actually installed one or know of someone who has?
Also, where to get the right meth from?
Cheers.
hmm sounds a bit risky to play with it when you dont know the history of it. The idea is to blend 50:50 water and methanol and add to the container which the system is connected to. Normal setups come with a dedicated tank and do not use the window washer bottle. Depends if the previous owner did a dodgy or removed the system?
You will need to find a supplier of methanol (methylated spirits is ethanol with a bit of methanol put in to stop people drinking it, so that wont work)
Most race fuel suppliers can supply methanol in 20Ltr or drums etc
Methonal is very dangerous and you dont want to smell/touch it etc. An option is to run just 100% water instead. That will reduce the air temperature but will not give more octane (methanol is like 120ron). A blend gets the best of water and methanol but having 100% water is easier to manage.
Apparently neither does the meth...guy at work reckons that when he had his own detailing business, one of his employees used to toss back a bottle of methylated spirits at lunch time...you know you have a problem when your alcohol doesn't even come from the liquor store.
oh man thats so bad haha
Nitro-meth is another level. Instead of using water-meth blend, you do a water-nitrometh blend. Moar powar
I refuse to jack off with anything but glitter lotion
Tuesday morning lulz
What did everyone do this long weekend?
I went on a 3 day bender.....
I think my heart stopped beating a couple times..
Helped a mate buy a s13 shell. Went to parents holiday house and fishing.... I've never really liked fishing, this time was different, it was good to just stand there pondering things. Fishing is kinda like extended shower time, Just stand there thinking about things.
