Anthony, saw you on Doncaster Rd yesterday, tried to wave but in hindsight, should have wind the window all way down and give you one hell of wave.
Also, drove a manual car for first time in weeks, forgot how fun it is, drove to chinese place then pizza then chinese again, pizza again then home, all this torturing dads Corolla was fun and gave him nice little surprise while I'm at it.
is it just me or do you guys find tons of websites just freeze your browser these days?
like google, try and search for anything, basically instant lock of the browser for several seconds
same with netbanking, instant lockups for seconds++;
Yep!
went to GP today, volunteering for NAB / St Johns...
FA18's are RAD, no matter how many times you see the same ol display, NOTHING will ever compare to that sound
Fark that thing was LOUD.
I am working in the GIO GTR pits, drop past tomorrow if you're there. :thumbsup:
lol damn! one of these days i will see you grant!
lol it would of been either on my lunch or after work im guessing :P
It was 6.30, and I were returning to work after lunch break.
And the BM does really blend right in. Need some racket to make it stand out.
Hey Anthony would you sell the factory Headunit out of the purple beast?
i normally would, but if i put it all back to stock id be throwing it back in >,<
ill have a think about it anyway mate :P
put a fluro stripe over the car! im sure ill spot it!
yeah i would of just finished work, stayed back a few hours to get some cars ready for the weekend
Can't own a skyline and fit in around here anymore!
haha
Seeing the GIO GTR was a surprise, just as i was planning to leave, see the GTR fly past haha. It was cringe-worthy seeing all those classics racing around, knowing that one poor man will be paying out of his pocket for any accidents. No multi-million, sponsorship deals like the F1 teams.
LOL, not putting anything on it, mum wants to sell it, haven't bothered to make an ad for it...
aha yeah i loveee them
i literally clean them after every drive to get rid of any brake dust
im so ocd =/
That's fine cos when I was rolling, people snap their necks to look at it at the Shoppingtown, good enough for me!
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
