Isn't Toyota starting the 86 at mid 30s?
Completely agree we pay too much should only be 10% more or so look @ lambo aventador is 900k here something like 190k of tax!
Sucks to be rich in this country
$30K for a car with a N/A Boxer 4 engine = LOL!
It's like an mx5 dont remember them being less and sold very well - they don't care if performance people like it just as long as it sells and sub 40k best you'll get like it
Hence why we buy a JDM import.
http://www.goauto.com.au/mellor/mellor.nsf/story2/EAF0B5B0781DD37CCA2579C20000B983
Fucking hell!
$30K - $40K
In the 2lt, inline 4 range, I'd go an EVO 6 / S-Chassis and they would be all turbo models for less the price.
Or for similar money, step up to a R32 / R33 GTR.
Or find Datsun Fairlady and go nuts.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
