whatever you do pick a workshop that provides an agreed warranty for the engine build
outlines the cost of the job and doesnt give you a surprise 2k extra bill at the end
and an agreed end date instead of "yeah soon" each month
Hmm
Who is it? Want someone who won't blow the engine up lol
Pm me brahhh... Might need to do 200kkm service soon
PM's sent
It's a specialised engine building workshop that does everything from street cars to full blown drag cars.
youre all wrong.
ric is half lebo, half black, half antarctican.
Nah, he is full HEKT1K.
Okay.
In regards of finding someone to put the motor together and tune it.
My mate thinks I should go to a place that does everything in house, as I'm getting Sposaro to build up the engine and he's outsourcing the tuning to Creatd.
Mate recommends JPC.
They built his drag VL, and his 400kw Xr6.....
So cownfushun
Don't your cousins own Rajab..?
LOL!
or at least if you cant find a workshop that covers warranty
at least you will know up front that its not covered
so if and when something goes bang you are aware of where you stand etc
ntohing worse than a nice build failing at start up, first run in or early KM stages
only for the owner to be told sorry not covered its your oil contimination or something etc etc
get as much info on what is covered and what isnt
ill be supplying the rods and pistons etc though.
if they can just cover their workmanship id be happy.
might just get creatd to do it.
trying to understand cams, springs etc.
f**k its confusing shit.
The line between workmanship and parts is incredibly blurred at the best of times.
Better yet Moh, buy a workshop manual and build the engine yourself. One of the most rewarding things I've ever done was build an engine! It's not that difficult, if you follow instructions carefully. Just like lego but with torque wrenches and tolerances lol.
what happened matt?
lol took a customer into the storage warehouse to look at some sinks, he says oh both your cars are in here, what do you drive daily?
me: the triton ute
customer: f**k bitches load fridges!
what happened matt?
Tried to do me for things that werent RWC items like a "soft" upper radiator hose. Rear pads were 2mm and legal limit is 1.5mm and I called him out on that and he got all defensive that oh well if you want to save $350 then we dont have to do it, then turned around and told me I should anyway. The owner of the company also told me to do some research to find out whats minimum spec for the rotors and get back to him.. like thats my job as a customer and all. Front tyres are Retreads (dont laugh, they came with the car) and the mechanic thought that meant they were damaged on the sidewalls, even though its just the cap glued on. Also tried to find the slightest imperfection in every bush so is trying to sting me for most of them in the rear and a couple in the front. All up about $1000 if I don't do the brakes.
(This is on a VLT also, none of this would happen on a skyline :P)
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
