Tried to do me for things that werent RWC items like a "soft" upper radiator hose. Rear pads were 2mm and legal limit is 1.5mm and I called him out on that and he got all defensive that oh well if you want to save $350 then we dont have to do it, then turned around and told me I should anyway. Front tyres are Retreads (dont laugh, they came with the car) and the mechanic thought that meant they were damaged on the sidewalls, even though its just the cap glued on. Also tried to find the slightest imperfection in every bush so is trying to sting me for most of them in the rear and a couple in the front. All up about $1000 if I don't do the brakes.
All for the VL?
Daf*k
All for the VL?
Daf*k
Indeed, I was going in expecting like $500 bucks. Silly me going to a jap RWC place for an aussie car... I'm dropping it off at the old mechanics tonight, he laughed at the brake and bushes comment so I should be alright, just means I wasted $165 on an inspection.
Lol they're distantly related to My cousin or someshit. I don't know.
LOL!
Just take it to Racepace.
:rofl:
Took a VLT to a Jap place for RWC.
Have been considering that Adam. I pulled it apart lol, how hard can it be?
Andrew. Whole cars in bits ATM lol
Can demolish a house faster than you can build it :thumbsup:
It's not difficult, just daunting. Probably not a good idea to attempt it if you're planning on using expensive high performance parts and you've much more to lose than just your pride if it doesn't work.
Woot Footy's back!
Anyone here play supercoach? :ph34r:
Since when did it go away, As far as I'm aware it plays for like 10 months of the year which is a pretty f*kn long winter for a winter sport.
i haaaate changing spark plugs on the rb25..
pffft. golf's easy as. is it cos you is armature?
i never said it was impossible... just pointlessly annoying.... the plenum setup makes the RB plenum setup look logical
also i'm talking about the 1.8 whereas you had the 2.0... not sure if there is a difference.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
